How to set inlet as a porous medium
Like Tree1Likes
  • 1 Post By geraldgrose
Old   December 12, 2023, 05:08
Default How to set inlet as a porous medium
Ghinna Nur Akram
gnakrammm is on a distinguished road
First I will say that I'm still new to CFD, especially ANSYS. So, I ask for your help.
I want to validate the method used in a paper entitled "Effects of different layouts of fine-pore aeration tubes on sewage collection and aeration in rectangular water tanks" with doi https://doi.org/10.1016/j.aquaeng.2020.102060 . I'm confused about understanding the sentence "The inlet was set as a porous medium, and each aeration arrangement required different outlet rates during the simulation." In this case, the inlet isn't just a surface placed at the bottom of the fluid domain? Because if I make fine-pore aeration tubes as a whole then the simulation will become very complex. Thank You.
gnakrammm is offline   Reply With Quote
Old   December 20, 2023, 23:56
gerald grose
geraldgrose is on a distinguished road
I want to validate the method used in a paper entitled "Effects of different layouts of fine-pore aeration tubes on sewage collection and aeration in rectangular water tanks" with doi https://doi.org/10.1016/j.aquaeng.2020.102060pico park . I'm confused about understanding the sentence "The inlet was set as a porous medium, and each aeration arrangement required different outlet rates during the simulation." In this case, the inlet isn't just a surface placed at the bottom of the fluid domain? Because if I make fine-pore aeration tubes as a whole then the simulation will become very complex. Thank You.
In CFD simulations, a porous medium is a region in the domain where fluid flow is modeled as occurring through a porous structure rather than through a clear, open flow space. The term "porous medium" does not necessarily mean a physical object like a surface at the bottom; instead,
gnakrammm likes this.
geraldgrose is offline   Reply With Quote
ansys, inlet, porous medium
[ICEM] ICEM Scripting Issues tylerplowright ANSYS Meshing & Geometry 33 September 27, 2021 17:35
Ansys Licence Serve on Ubuntu 16.04 LTS david.pasquale ANSYS 2 January 20, 2017 12:52
set different viscous resistance simulating flow through an anisotropic porous medium m_chiara_palu FLUENT 0 January 5, 2016 11:11
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
