Convergence in a supersonic intake
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   November 14, 2023, 02:50
Post Convergence in a supersonic intake
Adithya Ajay
Adithya Ajay is on a distinguished road
Hello there,
Hope all are doing well, I will directly jump in to the problem
My simulation of supersonic intake is not converging after a certain limit. Instead its oscillating. I know shock wave boundary layer interactiuons has inherent unsteadiness associated with it , so the residulas may oscillate while doing steady state analysis. But is there any way to reduce the residuals bit more?
In some cases, after oscillating for long iterations, temparature is getting limited by fluent. I made temparature contour and found that I am having extremely high tempearture outside my intake ( on the tip of external domain). Why this happens?
Images are attached here
1. Residual values after detecting divergence due to excessive temperature change.
2. Temperature contour after divergence detected
My mesh is very fine inside the intake !!
Adithya Ajay is offline   Reply With Quote
Old   November 14, 2023, 19:23
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
that's because of mesh
Adithya Ajay likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 15, 2023, 09:13
Default Please elaborate
Adithya Ajay
Is it because of mesh inside my intake or outside ( external domain). Min orthogonal quality is 0.9 , Max skewness is very less , but Max aspect ration is in the range of 100. Another thing I noticed on the mesh is : since I used stretching in Y direction to have Y+ 1, on the top side of the external domain cells are stretched perpendicular to flow direction.
convergence check, supersonic internal flows, temperature limited
Convergence issues in Supersonic flow Alpha_Ashwin007 FLUENT 4 July 6, 2023 23:26
Supersonic Convergence beschadigunc Main CFD Forum 3 June 2, 2022 08:36
Can't get convergence in subsonic nozzle Nicola_Fontana SU2 3 December 21, 2021 09:01
Convergence problem - intake manifold Nfcgfm STAR-CCM+ 12 April 7, 2010 21:39
Supersonic convergence in density based solver Charles FLUENT 0 May 10, 2008 18:55
