Niranjan
Rep Power: 10 ![]() |
.)Ansys Fluent Student version
.)Pressure inlet Pressure outlet boundary condition .)Long 10cm channel with 130 micron diameter with 3 inlet and two outlet at each end. Inlet pressure of 1atm and outlet pressure of 0atm. .)File 2- Pressure contour File 3-Density contour, File-4 Velocity contour & 5-Temperature. .)Argon working fluid .) Pressure based solver, K-Epsilon model,1000 Iterations .) 3D simulation, The results have are on a xy plane cutting along the geometry I don't know where I am going wrong. The pressure and velocity contour looks fine but density looks wrong. I don't think its a problem of mesh because along the long channel the pressure decreases and drops to zero at the exit. the density alone is not correct. Both pressure based and density based solvers are giving the same result. |
Alexander
Rep Power: 34 ![]() ![]() |
density is correct and shows constant values for the whole domain (same value everywhere)
best regards ****************************** press LIKE if this message was helpful |
density, need help with the error |
Natural Convection ! Boussinesq Vs Ideal Gas density | cfd_user_pune | ANSYS | 4 | September 15, 2020 08:46 |
[ICEM] Geometric density sources in ICEM | rana41671 | ANSYS Meshing & Geometry | 2 | June 14, 2018 05:44 |
Continuing User Defined Real Gas Model issues | aeroman | FLUENT | 6 | April 8, 2016 03:34 |
How to model Salinity, density, fresh water & sea water | grayback87 | FLUENT | 3 | December 30, 2014 02:00 |
density update by UDF in non-premixed combustion | IKSOO | FLUENT | 2 | December 8, 2002 20:37 |
