Automatic Case Modification Flow-Time doesnt add up
Like Tree1Likes
  • 1 Post By LuckyTran
Old   September 23, 2023, 16:45
Exclamation Automatic Case Modification Flow-Time doesnt add up
Marc
alphaNOVA is on a distinguished road
im using the automatic case modification in Fluent to start my calculations with a low cournat number. This is also set in the original settings. The original setting and my two other modification steps each use the "Flow-Time" specification on how long they should run. According to the Ansys Documentation the flow time i enter in this dialog is the flow time for how long the simulation will be carried out.
I set my Original setup to run for 7.5e-5s, the first modification for 17.5e-5s and the third on 1.825e-3 seconds. So i would expect the simulation running in total 2.5e-3 seconds. When i check flow time at the end of a simulation it varies between 3.5e-3 and 4.5e-3 seconds.
Did i understand the flow-time setting wrong or is there anything else i need to look out for in order to make the times add up? (simulating up to 4.5e-3 seconds nearly doubles my total required computation time - which i dont really can afford).
alphaNOVA is offline   Reply With Quote
Old   September 23, 2023, 17:39
Lucky
You don't add the flow time settings.
If you specify a flow time of 7.5e-5s then Fluent stops at or after 7.5e-5 s. If you then modify it to 1.825e-3 s then it stops at or as as soon as it can after 1.825e-5. It doesn't try to stop at 2.5e-3 and you shouldn't expect it to stop at 2.5e-3 based on this setting.
Now the question is why it vastly overshoots. Probably another one of your million automatic settings like allowing the Courant number maximum to be too high.
4.5e-3 seconds is clearly something you can afford because you did it without even trying!
alphaNOVA likes this.
Old   September 28, 2023, 06:22
Marc
Thank you for your input.
I am still not sure what caused it but i swapped to fixed time steps and now it seems to work the way i expected.
Because i can afford it on a coars test mesh with a single run does not mean its suitable for a larger parameter study.
automatic control, case modifications, flowtime, fluent
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 10:23
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
