Negative total heat transfer imbalance
Like Tree1Likes
  • 1 Post By CFDKareem
Old   July 25, 2023, 07:43
Default Negative total heat transfer imbalance
Waru
modorous is on a distinguished road
In Fluent, I am currently working on a heat transfer case involving two phases: coolant oil and air. The simulation includes the spraying of oil onto a metal geometry using a jet nozzle. The metal geometry has a heat source of 24 W, causing it to heat up to an average temperature of 90°C. The coolant oil is injected into the domain at a temperature of 40°C, and the surrounding area is filled with air at 20°C. To replicate the lab experimental setup accurately, I have extended the model to encompass a very large surrounding area around the metal geometry. The intention behind this is to account for the effects of natural convection cooling.
For the simulation, I have set up the following boundary conditions: a velocity inlet with a volume fraction of 1 for the oil, a pressure outlet with a volume fraction of 1 for the backflow air at 20°C. all other boundaries are adiabatic.
The simulation is conducted in a steady-state manner, and I have utilized the SST k-omega turbulence model. The multiphase model is VOF Implicit with implicit body force, VOF boundary is dispersed. The mesh incorporates 10 boundary layers, and all walls have a y+ value below 4, while the walls of the metal geometry have a y+ value below 1.
Currently, when calculating the total heat transfer imbalance, which considers the contributions from the inlet, outlet, and energy source, I am obtaining a value of -11W. I am guessing this is because the cooling effect from the large surrounding air domain is not calculated here.
My question is whether my assumption is correct, and if so, how can I incorporate the natural convection heat transfer from the surrounding air into the energy transfer imbalance calculation?
modorous is offline   Reply With Quote
Old   July 25, 2023, 14:18
CFDKareem's Avatar
Kareem
CFDKareem is on a distinguished road
The heat flux calculation takes into account the heat transfer from each boundary. If you imagine your domain as a simple control volume, then the amount of heat going in should equal the amount leaving (assuming steady-state). Due to numerical errors in CFD there will always be slight imbalance in the heat flux. However, it should tend to 0, not something high, like 11W.
The most common reason I have found for this is iteration error i.e. you are not letting your simulation run for enough iterations. Change your residual convergence criteria to something much lower (1e-6 at least) and let the simulation continue calculating. You should see the heat flux imbalance decrease.
modorous likes this.
Please like the answer if it helped!
Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured
CFDKareem is offline   Reply With Quote
Old   August 2, 2023, 15:46
Waru
Thanks a lot. Your advice helped. After 6000 iterations heat transfer rate was reduced. But this is too computationally expensive. So I reduced the domain size and it worked. Thanks again.
heat balance, heat transfer balance, heat transfer boundary, imbalance, multhiphase
how to set up a two way FSI with heat transfer? Shuo_Yuan FLUENT 1 June 25, 2023 04:12
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Post-processing: Diff between reports for Total Heat Transfer Rates beguxa FLUENT 0 May 19, 2020 07:22
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
