Hi I need to calculate Y+ value for jet Impingement over flat plate
Like Tree1Likes
  • 1 Post By CFDKareem
Old   June 9, 2023, 03:25
Post Hi I need to calculate Y+ value for jet Impingement over flat plate
G. Nithyanandham
Nithyanandham is on a distinguished road
Nithyanandham is offline   Reply With Quote
Old   June 9, 2023, 14:49
CFDKareem's Avatar
Kareem
CFDKareem is on a distinguished road
Y+ is dependent on the shear stress at the wall which is in turn dependent on the velocity. For an impinging jet on a flat surface, your velocity will be 0 at the stagnation point, hit a maximum a few units out, and then taper off as the jet spreads over the plate. If your first cell height, delta Y, is consistent along the impingement surface then your Y+ will match the velocity. To confirm this you can plot a graph of the velocity over the same distance and you will see a similar curve.
You should use the maximum value of Y+ for you inquiry. Depending on the wall condition/solver you will want the Y+ number to be <1 everywhere in domain. The regions where Y+ is >1 may not be accurate.
There is no need to use some different formulation of Y+. The phenomena you are seeing is correct and is not due to the calculation of Y+.
Nithyanandham likes this.
Please like the answer if it helped!
Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured
CFDKareem is offline   Reply With Quote
Old   June 12, 2023, 01:42
G. Nithyanandham
Thank you for your response.
jet impingement, sst komega, y+ calculation
Chien's Turbulence model for flow over flat plate (y+ query) Shiv1510 Main CFD Forum 9 June 19, 2019 16:32
transient heat in jet impingement on a flat plate waqarha2003 FLUENT 10 February 1, 2018 14:50
Calculate Skin Friction Coefficient in a plate with a roughness pattern Kyoto FLUENT 0 August 23, 2013 23:52
Conjugate heat transfer for film-cooled flat plate Michele FLUENT 0 July 3, 2006 09:42
flat plate boundary layer data Ekachai Juntasaro Main CFD Forum 3 March 14, 2001 00:18
