April 22, 2023, 06:12 |
Pressure boundary condition
Yaroslav Ivanov
Hi!
I have pipeline which lead from gas balloon to vacuum chamber. Gas is injected into the chamber from a gas pipeline. The Static pressure was measured at the beginning of the pipeline. It amounted to 160 Pa. The pressure in the chamber is less 1 Pa. I am need to know distribution of pressure in pipeline. How to correctly set the boundary conditions using only the static pressure at the inlet and outlet? Thank you! |
April 23, 2023, 07:21 |
Lorenzo Galieti
Rep Power: 12 |
you need to presume the static pressure at the inlet is more or less equal to the total pressure. This is fine if you have highly subsonic flow.
Assigning two static pressures is a bad idea. It cannot even be done I think. |
fluent, pressure b.c, static pressure |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Appropriate pressure boundary condition in incompressible flow | lonelywing | OpenFOAM Running, Solving & CFD | 21 | June 6, 2022 10:44 |
Question about different kinds of Boundaries and Boundary Conditions | granzer | Main CFD Forum | 17 | April 12, 2022 18:27 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
