Determining shockwave location in Ansys
Like Tree4Likes
  • 1 Post By NickFL
  • 1 Post By NickFL
  • 1 Post By NickFL
  • 1 Post By NickFL
Old   March 25, 2023, 05:39
Default Determining shockwave location in Ansys
Transonic is on a distinguished road
Hi, is it possible to determine the shockwave location in Ansys fluent please?
What I wanted to know was where along the chord length of an aerofoil, the shockwave is like this graph has done
Thanks in advance
File Type: jpeg 9B4FE34D-8BF7-4F70-9D00-D71E4A560081.jpeg (47.2 KB, 23 views)
Transonic is offline   Reply With Quote
Old   March 27, 2023, 06:05
NickFL is on a distinguished road
Across a shock wave we will have a sharp change in pressure, velocity, density, etc. We can use that to guide us where the shock location "is".
Transonic likes this.
NickFL is offline   Reply With Quote
Old   March 27, 2023, 11:22
Hi, so it be correct to just make a pressure plot over the surface, then where the pressure starts to jump, is where the shockwave begins?
Old   March 27, 2023, 15:14
Yes that would be one way. Perhaps a more elegant way would be to plot the derivative of the pressure. Where this is a maximum, that would give you the location of the shock. Are you looking at 2D or 3D flow?
Old   March 27, 2023, 15:39
Hi Nick, I’ll give that a shot, I’ve never thought about it like that. Would I be plotting that over the aerofoil please?
2-D transonic flow
Old   March 28, 2023, 03:27
I am not sure exactly on what type of solution you are attempting. But keep in mind that depending on the airfoil, Mach Number, and angle of attack there can be multiple "correct" solutions. See: https://www.researchgate.net/publica..._Flow_Equation
Old   March 28, 2023, 09:49
Hi Nick, I couldn’t find the pressure derivative?
File Type: jpg E706B23B-FBA6-4BF1-A68B-7DAAB02B3130.jpg (82.3 KB, 10 views)
Old   March 29, 2023, 04:02
Really? Sorry! I would have expected Fluent to include the gradient of pressure in as a post-processing quanitity by now. I would have expected that since the gradient is computed for the mesh adaption it could be accessed. Silly me for assuming anything.
You can create a post-processing scalar variable using a UDF. The UDF does not need to be run during the solution, only when looking at the results. There is a great example in the UDF guide where they create a UDS (user-defined scalar) for the gradient of T^4 (radiation problem). You could easily adapt that.
Edit: See example 8.5.2.1 here: https://ansyshelp.ansys.com/account/...ampleUDFs.html
Old   March 29, 2023, 10:22
Hi Nick, no problem! Yeah, I thought I had seen it too somewhere and thanks for the link, I’ll take a look!
airfoil 2d, fluent, shockwaves, super sonic, trans-sonic
ANSYS fluent and OpenFoAM comparison gentodin Main CFD Forum 6 February 26, 2021 04:58
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
CFX FSI Fatal Error unbanana CFX 0 October 3, 2015 06:57
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 02:10
