Dividing a Plane into Slices
Like Tree1Likes
  • 1 Post By NickFL
Old   March 21, 2023, 01:20
Default Dividing a Plane into Slices
wockenz is on a distinguished road
I need to calculate pressure distortion coefficent on the area of 1/6 of the measurement plane. How to create 60 degrees sector on the plane in Ansys Fluent?
wockenz is offline   Reply With Quote
Old   March 21, 2023, 04:01
NickFL is on a distinguished road
Without know a bit more it will be hard to give the best answer. But there is a variable in the Mesh group called Angular Coordinate. Depending on the orientation of your model you may be able to use this and an Iso-Clip using this variable.
wockenz likes this.
NickFL is offline   Reply With Quote
Old   March 21, 2023, 04:24
Thanks for your reply. I'll try this. To be more clear, i drew a plane. I want to work on the area shown with X in the image to calculate distortion coefficent.
Old   March 21, 2023, 06:01
This worked btw, thank you.
divide plane, pressure distribution
Gmsh Structured mesh that crached in openFoam simulation basma OpenFOAM 0 August 2, 2022 15:39
Mass Averaging on meridional slices of a plane ValorToMe STAR-CCM+ 0 November 26, 2020 11:59
OpenFOAM error Vinay Kumar V Main CFD Forum 0 February 20, 2020 10:17
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
