March 17, 2023, 09:25 |
Writing a Script to Get Datas from Fluent
Rep Power: 3 |
I am going to run lots of analysis so i need to write a script which gets datas like maximum, minimum and average pressures and velocities for several planes automatically after the solution done. I searched it but didn't find anything. Can you help me, please? |
March 17, 2023, 12:07 |
Rep Power: 17 |
The solution is to use journal files. These are basically the commands that are needed to get the desired quantities. You can use journal files to create the planes, get the averages, write it to a file, etc. You could even use it to open the next data file and do all the actions again.
March 19, 2023, 13:01 |
#3 | |
Rep Power: 3 |
fluent, post process, scripting |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 12:04 |
[ANSYS Meshing] Export mesh as fluent msh by using script | erkut | ANSYS Meshing & Geometry | 0 | July 13, 2018 16:41 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
