March 17, 2023, 07:52 |
Mass flow for symmetric geometry
Andrew
Rep Power: 3 |
I have a 3D geometry of a pipe, which is cut down the center (r = 0) to exploit symmetry. So, the inlet and outlet faces are half-circles.
If I compute the mass flowrate at the inlet/outlet, does it adjust for the symmetry? I.e., with a mass flowrate of 1 kg/s, is it 1 kg/s for a half circle area or the whole circle area? Thanks! |
March 17, 2023, 09:21 |
Lucky
Rep Power: 66 |
If you are specifying mass flowrate in kg/s then flowrate is according to the area that is in the mesh. You should provide a half-circle worth of kg/s.
If you have other BCs and are post-processing and using a mass flow report, then Fluent is reporting you the half-circle worth of kg/s and you need to multiply it by 2 to get the flow that you would have obtained through a full circle. |
March 17, 2023, 10:11 |
Andrew
Rep Power: 3 |
Great! Thanks for your quick reply.
mass flowrate, symmetry |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 17:22 |
An error occurs.'Increase the file catalog size. ' | dhehdxhdaus | CFX | 3 | April 10, 2022 20:13 |
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate | MSchneid | Fluent UDF and Scheme Programming | 3 | February 23, 2019 06:00 |
Discrete Phase & Mass Flow Rate | MagnusZeus | FLUENT | 0 | December 2, 2011 17:57 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
