Pratik Chalke
Rep Power: 3 ![]() |
Well my Velocity at inlet and outlet are about 2m/s and 3.5m/s respectively, but I am getting relatively high velocities in the impeller region also I the velocity contours have centre at different location then the impeller. Is this because the rotation origin I have provided is wrong? Because I changed the origin of geometry in Spaceclaim before meshing, although the geometry was designed in Solidworks. |
MC
Rep Power: 5 ![]() |
The erroneous behaviour you see may have several causes, from modeling (mesh, solver...) to geometry and boundaries.
Without further info, I cannot help more |
#3 | |
Rep Power: 17 ![]() |
Pratik Chalke
I recreated the geometry and did everything over again, and now Velocity Contour seems to be normal but now I am getting issue in CFD POST where the streamlines are not complete till the end if anyone knows please help.
![]() https://drive.google.com/file/d/1Jun...ew?usp=sharing https://drive.google.com/file/d/1yka...ew?usp=sharing https://drive.google.com/file/d/1OPZ...ew?usp=sharing |
MC
I had a similar issue once, and I could not solve it in CFD-post. I had to switch to Ensight, where the streamlines are treated better.
Maybe someone can provide better help. |
Yes CFD Post has problems when crossing an interface, but it is much better than what is Fluent post-processing. The problem arises from a drastic change of the angle in streamlines at the interface. There are settings where you can change the integration accuracy, and it may let some through. Looking at the velocity contours, I can almost visualize the grid. This is an indication that integration along the streamlines will change per control volume, and at the interface it gives up.
Go back and double-check the interfaces. What rotating model are you using at the interface? What does the mesh look like? |
Pratik Chalke
The contours are not smooth. If you were to plot the mesh on the same plane as these velocity contours, I would expect the contours to follow the mesh lines. This is an indication that the mesh should be refined and that uncertainty in the integration could be the reason why the streamlines end. Are you limited to a certain number of elements (student license or something similary)? If not, maybe increase the resolution and see if that helps.
#9 |
Pratik Chalke
Thank Your very much for your help, I will try what you said.
fluent, origin, velocity |
Import .csv - velocity profile - error | eSKa | CFX | 9 | April 3, 2021 13:38 |
UDF comilation error. urgent help please | m zubair | Fluent UDF and Scheme Programming | 4 | February 10, 2019 11:19 |
wrong velocity contour of rotating propeller - Fluent | calv | FLUENT | 1 | September 6, 2018 11:48 |
How to find torque and angular velocity in Fluent? | aacheng30 | FLUENT | 0 | November 26, 2017 07:11 |
In fluent post processing, difference between, x velocity and axial velocity? | padmanathan | FLUENT | 3 | December 20, 2014 15:13 |
