March 3, 2023, 15:39 |
y-gravity in 2D axisymmetric case
Andrew
Rep Power: 3 |
A simple clarification question -
In a 2D axisymmetric case, the x-axis is the axis of symmetry. Then, applying gravity in the +x or -x direction simulates a vertically-oriented tube (gravity acts axially). Does y-directed gravity then simulate a horizontally-oriented tube? (This makes the most sense to me, but then the domain is not exactly symmetric). Or, would it simulate a tube with gravity always directed radially/towards the center? (This would preserve symmetry, but I can't imagine why this would be useful). If anyone can confirm that y-directed gravity in 2D axisymmetric case simulates a horizontally-oriented tube, I'd greatly appreciate it. Thanks! |
March 6, 2023, 12:02 |
Alan
Rep Power: 4 |
Fluent requires that the axis of symmetry is on the x-axis. In this case, no fluid can cross the symmetry axis, and no fluid is expected to move in the tangential direction. Therefore the gravity expressed in the y-direction would be the same as expressing it in the radial direction and is not the same as simulating a horizontally oriented tube.
If your problem contains just one phase, check if gravity can be neglected. If gravity is important, do a 3D simulation. |
axial, axisymmetric, gravity, tube |
Issue of FvDOM radiation model in 2D axisymmetric case | Junjun Guo | OpenFOAM Running, Solving & CFD | 0 | January 29, 2021 16:28 |
MRFSimpleFoam wind turbine case continuity error | ysh1227 | OpenFOAM Running, Solving & CFD | 1 | August 16, 2016 10:25 |
Axisymmetric Case 3rd Velocity Component | Mentalo | OpenFOAM Running, Solving & CFD | 2 | June 8, 2014 13:45 |
Heat flux BC in axisymmetric case | kevin | FLUENT | 0 | February 7, 2008 19:07 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
