How to calculate penetration depth of a rigid body impinging in water?
Like Tree3Likes
  • 1 Post By CFDKareem
  • 1 Post By PacMan
Old   February 10, 2023, 05:07
Default How to calculate penetration depth of a rigid body impinging in water?
Deepankar
Deepankar is on a distinguished road
I am working on Numerical Analysis of rigid body impinging in water using Ansys Fluent in which I have to calculate penetration depth of that body in the water. I am unable to do that kindly help me regarding that.
Thanks & Regards!
Deepankar is offline   Reply With Quote
Old   February 10, 2023, 11:54
CFDKareem's Avatar
Kareem
CFDKareem is on a distinguished road
Originally Posted by Deepankar View Post
Thanks & Regards!
I'm going to assume the body is traveling down along the Z axis, but you can change it for whatever axis it is moving along.
You can plot a report definition for the minimum Z value of body. This will create a plot of the bottom edge of the body over time. If you know the level of the water then you can calculate how far the body penetrates. I would recommend drafting your domain with the water level at 0. Then, from you plot, the minimum value it achieves will be the penetration depth.
Deepankar likes this.
Please like the answer if it helped!
Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured
CFDKareem is offline   Reply With Quote
Old   February 11, 2023, 03:35
Deepankar
Thank you sir for this but if you can tell how to plot minimum Z value of body and how to predict the penetration depth by knowing water depth. I am still unable to do, I have to show the plot of penetration depth w.r.t. time. My domain is 1.5*1.5*7m and water depth I took is 2m and a cylinder with hemispherical head of radius 0.2m and length 0.6m is dropped from air(free fall) from a height of 3m.
Can you please tell me from scratch or if possible please make a video on this?
Old   February 17, 2023, 11:09
CFDKareem's Avatar
Kareem
I would love to make a video on this. It will be much easier to explain.
Could you provide some images of your domain as well as the boundary conditions such as the size and speed of the sphere?
Old   March 4, 2023, 03:13
Deepankar
Could you provide some images of your domain and the boundary conditions, such as the size and speed of the sphere?
The body I took is a cylinder with a hemispherical head of radius 0.2m and length 0.6m dropped from the air(free fall) from a height of 3m. The water depth is 2m, and the domain size is 1.5*1.5*7m. I just took the boundary condition as the fluent took automatically means all the walls of the domain are wall boundary conditions. I took the top wall of the domain as the specified pressure boundary where I have given a pressure inlet.
I used a dynamic mesh where I took only The body as the component zone and considered it as a rigid body only, mapped it with the mass of the object 19kg and took One degree of translation, and put the "y" value as 1. And did the hybrid initialization and patched it. I have taken two phases 1st is air and second is water.
File Type: jpg Screenshot 2023-02-11 at 1.48.32 PM.jpg (63.7 KB, 4 views)
File Type: jpg Screenshot 2023-02-20 at 11.21.09 AM.jpg (78.2 KB, 4 views)
Old   March 4, 2023, 03:17
Deepankar
I used a dynamic mesh where I took only The body as the component zone and considered it a rigid body, mapped it with the mass of the object 19kg and took One degree of translation, and put the "y" value as 1. And did the hybrid initialization and patched it. I have taken two phases 1st is air and second is water.
And also, one more problem is there, sir. When It hits the water surface, it doesn't create any splashes, and no water surface breaking is observable. What to do , where I am doing wrong? Kindly provide some solution.
Old   March 6, 2023, 11:22
Alan
PacMan is on a distinguished road
Are you using VOF? what are the boundary conditions on the moving object?
PacMan is offline   Reply With Quote
Old   March 9, 2023, 04:43
Deepankar
Yes, I am using VOF. And I am attaching screenshots of all the steps I took in the setup part numbered in sequence. Kindly look at that.
I have taken the body as a component zone and the domain as the background zone.
All the walls of the domain I took as walls-background except the upper wall.
For the upper face wall, I have taken the "specified pressure zone," which I gave as pressure inlet (Atmospheric pressure), as you can see in the screenshots.
Last edited by Deepankar; March 9, 2023 at 05:08. Reason: I have to add Screenshots also
Old   March 9, 2023, 05:07
Deepankar
#ansys#fluent
interDyMFoam - One rigid body, multiple boundaries mattkram OpenFOAM Running, Solving & CFD 1 March 29, 2021 09:36
Rigid body motion on transient fluent mrf ghost82 EnSight 4 September 6, 2014 12:24
Oscillation airfoil in infinite water depth ldb83 FLUENT 14 June 4, 2013 09:03
Free water jet impinging hot solid surface, including boiling hamdy Fluent UDF and Scheme Programming 5 August 19, 2012 20:52
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
