February 4, 2023, 09:16 |
warning cant identify any field of profile
zhubin
Rep Power: 4 |
Guys, I have a problem with dynamic mesh using transient profiles.
the profile (.txt) is shown here: profile-v 2 14 0 time inlet-v 0 0 300 0 310 1.538E-4 9790 1.538E-4 9800 1.667E-4 9910 1.667E-4 9920 9.524E-5 10330 9.524E-5 10340 4.762E-5 11590 4.762E-5 11600 1.667E-5 13990 1.667E-5 14000 1.111E-5 15790 1.111E-5 It is used to define the rigid body motion of inlet. After File-Read-Profile, it shows "Reading transient profile file... 14 "profile-v" transient-profile points time, inlet-v,." in the console, and the "profile-v" is shown in Motion UDF/Profile as an option. However, after the dynamic mesh zones setting and click Display Zone Motion, it says "Warning: Can't identify any field of profile profile-v. No motion specified. Warning: Can't identify any field of profile profile-v. No motion specified. ........" I have tried standard profile and .csv, the results is the same. So, has anyone meet the same warning? Can you tell me how to solve it? Last edited by zhu-jsut; February 4, 2023 at 09:18. Reason: hard to read |
February 4, 2023, 12:05 |
Alexander
Rep Power: 34 |
((sampleprofile transient 3 0) (time 1 2 3 ) (u 10 20 30 ) )
best regards ****************************** press LIKE if this message was helpful |
February 5, 2023, 01:10 |
problem solved
zhubin
Rep Power: 4 |
dynamic mesh, transient profiles, warning |
[OpenFOAM] ParaView command in Foam-extend-4.1 | mitu_94 | ParaView | 0 | March 4, 2021 14:46 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 07:59 |
