Rep Power: 3 ![]() |
Hello! I want to simulate a section of a 2D channel using periodic inlet and outlet surfaces to obtain a fully developed turbulent channel flow.
I have set a periodic BC in the outlet using the inlet as the shadow zone. However, when I do it, the inlet and outlet sections are removed from the BC tree. How can I impose a velocity inlet and a pressure outlet BC in this case? Should I impose any pressure drop along the channel for the solution to converge? Thanks |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
In Fluent there is a periodic conditions tab where you specify the conditions. You can specify the pressure gradient or the mass flow rate.
boundary condition, channel flow, periodic bc |
Conformal mesh for periodic BCs | Kev | ANSA | 1 | September 19, 2021 12:36 |
Can I achieve better convergence? | sheaker | CFX | 12 | September 19, 2019 15:36 |
How do I find the pressure drop in translationally periodic wavy channel flow? | dfonseka | ANSYS | 0 | April 26, 2018 17:03 |
Wavy channel periodic BC's | Rashed | ANSYS | 1 | December 6, 2017 08:04 |
periodic channel flow | roadRunner | STAR-CCM+ | 0 | June 25, 2015 07:32 |
