Calculation of the Inlet Area in Axisymmetric 2D Simulation |
December 22, 2022, 07:04 |
Felix Leh
Rep Power: 5 |
Hi guys,
i am wondering how fluent calculates the surface area of a inlet surface in a 2d axisymmetric simulation. I try to simulate the flow of two gases (air and methane) through a combustor in a combustion chamber. A drawing of the geometry is attached. In my opinion the real surface area of "Inlet 1" is S1 = pi*R1^2 = 28.27 mm2 since the line of "Inlet 1" with the length of R1 leads to a circular surface. BUT Fluent says the surface area of "Inlet 1" is 405.27mm2 (im reporting the surface area of "inlet 1" in the calculation. The real surface area of "Inlet 2" should be S2 = pi*R3^2 - pi*R2^2 = 480.66mm2 since this is a annular surface. But Fluent says the surface area is 1611,6 mm2... Does anybody know how fluent calculates these surface areas? |
December 23, 2022, 12:39 |
Kareem
Rep Power: 5 |
If the domain is setup correctly, the area should be correct (see picture).
For axisymmetric models the axis of revolution is the X-axis, not the edge you defined as "axis". Make sure your domain is located directly on the X-axis. From the numbers you are getting it looks like the axis defined is off the X-axis.
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
December 27, 2022, 06:52 |
Felix Leh
Rep Power: 5 |
thank you for your answer. My Problem was that my "axis" was NOT located at the x-axis. |
axisymmetric 2d fluent |
Gradient calculation for axisymmetric simulation | Wouated | STAR-CCM+ | 1 | August 9, 2019 17:09 |
[OpenFOAM] Problem with cell area calculation in a slice | daniel87 | ParaView | 5 | October 24, 2015 17:18 |
swirl inlet velocity for a 2-d axisymmetric flow | zahrarashidi | OpenFOAM Running, Solving & CFD | 2 | January 12, 2015 08:01 |
Incorrect pressure calculation at inlet | Floszwa | CFX | 10 | November 7, 2014 05:11 |
Axisymmetric Reference Area | jack1980 | FLUENT | 0 | October 16, 2009 10:34 |
