dynamic mesh layering changed after run calculate |
zhubin
Rep Power: 3 ![]() |
hello, everyone
I have a question about the dynamic mesh. The initial 2D mesh is very simple, two layers of 10mm height quad mesh. One edge moves with a velocity defined by UDF: DEFINE_CG_MOTION(dm_top, dt, vel, omega, time, dtime) { NV_S(vel,=, 0.0); NV_S(omega,=, 0.0); real time; time = CURRENT_TIME; if(time <= 320) vel[0] = 0.0; else if(time > 320 && time <= 480) vel[0] = 0.000125; else if(time > 480 && time <= 1000) vel[0] = 0.0002; else vel[0] = 0.0; } As shown here, the velocity is 0 in the first 320 seconds, and then the edge starts to move. The dynamic mesh setting, preview mesh motion, every thing is OK. As shown in preview mesh motion, the mesh has two layers until 320s, and then the layering starts. However, the initial mesh (from 0s to 320s) became 4 layers after the initialization and run calculation, as shown in the mesh animation. Still, the simulation results conform to the logic, and the layering starts just after 320s. And if I extend time steps, the number of grid layers continue to increase but keep unchanged from 0s to 320s. So, if anyone has ever encountered this problem, please tell me the possible reasons. |
zhubin
Alexander
Rep Power: 34 ![]() ![]() |
compile your code, so you will avoid such problems later
variable time is already defined as a parameter of function, you don;t nee to redefine it remove Code:
best regards ****************************** press LIKE if this message was helpful |
#4 | |
zhubin
![]() It is my first post on this forum. thanks again ![]() |
dynamic mesh; layering |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
Mesh Disappering with Dynamic Mesh | FaroukH | FLUENT | 0 | February 23, 2021 18:26 |
Interfoam and dynamic mesh with layering (OF1906) | nkalkote | OpenFOAM Running, Solving & CFD | 0 | July 17, 2019 01:57 |
dynamic mesh interDyMFoam parallel run and processor boundaries | lukasfischer | OpenFOAM Running, Solving & CFD | 0 | August 12, 2009 06:36 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
