aloktkr
Rep Power: 3 ![]() |
There is a small pipe inside a box, one surface of box is inlet and opposite surface of box is outlet, also, that pipe inside box has also one inlet on one side and other on opposite side, I am providing the conditions of two velocity inlets and outlets are pressure outlets. so when simulationsa are over, the velocity field is not merging with each other and remains discontinuous, I tried applying boolean substraction but then the flow was over the pipe. Dont know how to proceed.
Kareem
Can you explain a little bit more about what your intended results are? From the description, it sounds like a flow over a pipe. Are you trying to have the pipe empty into the box?
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
aloktkr
yes the pipe is empty
Kareem
If I understand correctly and you have a box with a pipe entering and emptying into the domain, then there is two ways to do this.
The first, and best way, would be to make the entire domain one solid, or 1 cell zone. Create a void where the pipe is, assign inlet to the top, assign inlet to the pipe, and outlet on the bottom (or side). The two flow streams will enter the domain and combine. See picture "xxx_1zone". The second, which is how I believe you are doing it now, is using 2 cell zones. If this is the case you should make the interface wall "interior" in Fluent. In the attached picture, this interface is labeled in orange. Apply the inlet to the pipe, inlet to the box, and outlet to the box. The "interior" condition will couple these two cell zones and allow the flow from the pipe to empty into the box. See picture "xxx_2Zone". Let me know if I understand this correctly.
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured Last edited by CFDKareem; December 12, 2022 at 12:23. Reason: Clarification |
aloktkr
Please see the image attached,
there were results for it, but I wanted continuous field, as then I have to use DPM for particle tracking as well Thanks for your reply |
#6 | |
Kareem
In meshing, label your pipe inlets (ex. PipeIn) and label your pipe exit (PipeOut). In Fluent, assign the PipeOut as "interior" and assign the "PipeIn" as "Fan". You can now give a pressure jump at this interface to achieve the required flow and recirculation. For more information on setting the fan profile check out the fluent theory guide. See attached pictures for details. Let me know if this is what you are looking for!
aloktkr
Hi thank you for the reply, actuall in design modeler first I have drawn a sketch and then surface from sketch so one body is made, than one body I made inside it using same, how to merge these two bodies so that they behave like one. I tried creating new part and share topology but couldn't do so.
Alexander
Rep Power: 34 ![]() ![]() |
in your case both zones are into one part, you don't need to share topology
best regards ****************************** press LIKE if this message was helpful |
Simulation of flow inside bottle at different inlet pressures. | maitray | FLUENT | 2 | October 12, 2017 23:14 |
massflow inlet on cooling plate definition inside the ambient air box | farianka | FLUENT | 0 | March 21, 2017 06:27 |
Velocity inlet inside another zone | Arttis | FLUENT | 0 | March 4, 2017 12:20 |
[Other] How to define internal walls for injector inside a combustion chamber by OF2.1.1 with | sandy13 | OpenFOAM Meshing & Mesh Conversion | 0 | May 22, 2013 06:59 |
Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 18:42 |
