No pressure data on solid faces of a solid-fluid contact |
Rep Power: 4 ![]() |
Good day everyone,
I am new to fluent and make a simple simulation. I can get correct temperature distribution and pressure on fluid domain. On the solid-fluid conatact faces, I can get the pressure on fluid-side, but no data on solid-side. Could any one explain the reason for me and teach me how to fix the problem? Best regards, ZHU |
Alexander
Rep Power: 34 ![]() ![]() |
pressure is calculated only in fluid region, not in solid
make a sketch if you still have questions
best regards ****************************** press LIKE if this message was helpful |
Thank you for your information.
As in the picture, on the contact face of solid-fluid, pressure only available on fluid side. What I need is to tranfer the water pressure to static structurals as a load. And I found the static structrual do not work with fluid (I think the reason is fluild material do not have elastic properties). So I need to surpress the fuild domain. Then I need the pressure on the solid face which contact with fluid. Best regardings, ZHUBild1.jpg |
#4 | |
Kareem
Rep Power: 5 ![]() |
First, you can plot a contour on the interface wall between the fluid and solid domain. This will show the pressure at the interface. contour>new>pressure contour @ interface wall You can export this pressure to a csv by going to: File>export>profile Select the interface wall, select pressure, and export the csv. For a simple model, you can make an assumption of the pressure by averaging over the surface. To do this go to the results tab, select surface integrals, select area-weighted-average, pick you interface wall, and select static pressure. This will give you a single value for the average pressure at the wall which can be easily set as a load in static structural model.
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured Last edited by CFDKareem; December 7, 2022 at 13:24. Reason: Spelling |
pressure |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 13:50 |
[snappyHexMesh] SHM Layer Addition Phase | dickcruz | OpenFOAM Meshing & Mesh Conversion | 4 | November 1, 2018 08:05 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 15:49 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
