Subtract temperature plots to find effect of changing parameter(s) |
December 1, 2022, 15:04 |
David
Rep Power: 5 |
Is there a way to find the difference between two temperature contours? I am thinking this would be a nice way to visualize the effect certain parameters have on the temperature field by visualizing ΔT. I assume, to begin with I would need to be working with the same exact mesh file so that all the node values line up. However, I'm not sure if this type of post-processing is available. Perhaps if I could export the node values I could create a plot in Matlab or similar software. Has anyone tried this before? |
December 3, 2022, 20:16 |
#2 | |
Kareem
Rep Power: 3 |
December 4, 2022, 09:12 |
David
Rep Power: 5 |
Awesome! Thanks
PEMFC Model in Fluent - Effect of temperature | Rui_27 | Fluent UDF and Scheme Programming | 5 | March 17, 2021 21:27 |
Effect of gas dissolution and temperature gradients | Mbakli | FLUENT | 0 | September 23, 2013 08:19 |
how to find bulk temperature plot and results in fluent | cadcamvijay | Main CFD Forum | 2 | March 21, 2009 00:36 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
temperature not changing! | lizhihua | Siemens | 0 | September 14, 2007 09:29 |
