How to enter timestep(fo having several cycles) in FSI simulation in fluent? |
November 30, 2022, 01:38 |
naji
Rep Power: 4 |
Hi friends
i'm doing a simulation of blood flow with fsi modelling i want to do the simulation in 5 cycles. the question is: how should i enter the number of time step to have several cycles? and where? i thought for 1 seconds of simulation and time step of 0.01 i should enter the number of time step 500(5 cycles) and time step in fluent and end time and time step in coupling and the same in transient structural but at the end the solution goes for 1 cycle only and all the numbers were changed in fluent section. can anybody point the problem and the way of solving? it would be so appreciated. here is a picture of 3th cycle to help you realize what I'm saying better : |
November 30, 2022, 01:59 |
#2 | |
Alexander
Rep Power: 34 |
best regards ****************************** press LIKE if this message was helpful |
November 30, 2022, 03:24 |
#3 | |
naji
Rep Power: 4 |
I'm using udfs for inlet and outlet velocity and pressure how come? how does it affect the time step? i don't want the fluent section to change,how can i fix this? now i also tried to do it in another way but it's still changing |
November 30, 2022, 03:31 |
#4 | |
Alexander
Rep Power: 34 |
show your UDF when you are saying "all the numbers were changed" it's not clear what exactly you are talking about. The Graph you showed is not readable ( at least show first cycle (which is correct according to what you've said) and second (which is incorrect)) as you are using FSI - the shape of geometry suppose to change which should lead to change in flow,s o may be change you are talking about is normal. check it
November 30, 2022, 03:46 |
#5 | |
naji
Rep Power: 4 |
-------------------------------------------------------------------------------------------------- i know that it makes only 1 graph per 1 solution running the reason why I'm using more cycles is for the sake of "convergence" i think they should repeat 5 times during the solution not be ready at first in the udf.am i right? Last edited by aiden_1995; November 30, 2022 at 05:48. |
November 30, 2022, 04:08 |
#6 | |
naji
Rep Power: 4 |
about the time step you were right-let me make it more clear by explaining on a picture: this is my Fluent's time step setup after ending the solution: "the number of time steps which i entered and was 500(100*5cycles)has changed to 1 and the time step which was 0.01 turned to 0.0099999..." ---------------------------------------------------------------------- ---------------------------------------------------------------------- and i filled the rest of it for coupling and transient structural like what i mentioned before |
November 30, 2022, 04:13 |
Alexander
Rep Power: 34 |
as your simulation is transient it doesn't make sense to simulate several cycles to get converged simulation
increase number of iterations per time step, if you are not sure check mass balance convergence (difference between in\out mass flow rates) for each iteration -> in perfect case it should converge for each timestep however, if you want to simulate several cycles add t = t%1; into your code for both profiles Code:
real t = CURRENT_TIME; t = t%1; begin_f_loop(f, thread)
cycles, fsi, time step |
Transient simulation in Fluent | khaham | FLUENT | 13 | March 15, 2016 09:18 |
Oscillations of force and flow rate within FSI simulation of biomedical valve | jtwilson | FLUENT | 0 | September 23, 2015 14:26 |
1way FSI simulation using ansys structural and Fluent | mmkkeshavarzi | FLUENT | 0 | August 5, 2015 11:49 |
Thermal Simulation using Multiphase VOF model in Fluent | hari.poudyal47@gmail.com | Fluent Multiphase | 0 | July 20, 2015 12:31 |
FSI : CFX or Fluent? | icemaniac178 | ANSYS | 1 | February 19, 2010 07:33 |
