Using results from simulation A in simulation B
Like Tree1Likes
  • 1 Post By alainislas
Old   October 8, 2022, 09:19
Default Using results from simulation A in simulation B
Hafssa is on a distinguished road
Hello guys,
I want to simulate a multi-tubular reactor.
The first step was to simulate only one tube of this reactor to validate the model. (Simulation A)
Then I will need to simulate the whole reactor. (Simulation B)
The geometry in simulation B contains 7 of the same geometries in simulation A.
My question is there any way to get the results from my first simulation and use it in my second simulation (this will allow me to gain time )?
I would appreciate any hint.
Thank you
Hafssa is offline   Reply With Quote
Old   October 8, 2022, 19:29
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
1) Under File->Interpolate you can "write" the solution of simulation A.
if the mesh of simulation B is referenced to the same origin coordinates as of simulation A, then you can:
2) Open a fresh session in Fluent, load your mesh of simulation B and read the fields that you just saved. Again you can find this under File->interpolate "read".
Hafssa likes this.
alainislas is offline   Reply With Quote
Old   October 9, 2022, 04:19
Thank you alainislas. I will try it.
simpleFoam: Influence of MRF region dimensions on simulation results Krao OpenFOAM Running, Solving & CFD 4 March 29, 2022 22:33
Difference between 2D and 3D simulation results Tuck FLUENT 2 January 9, 2021 18:43
Export simulation results for MATLAB Anand Ashish FloEFD, FloWorks & FloTHERM 3 July 22, 2016 05:17
Results of an axisymmetric simulation in Fluent ShimiSan FLUENT 0 July 19, 2016 10:20
simulation results don't match with experimental results funquest CFX 2 January 19, 2013 21:24
