Fluent: Warning: zone of type interior found between different solids!
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   October 5, 2022, 06:09
Default Fluent: Warning: zone of type interior found between different solids!
Milad MU
Milad06 is on a distinguished road
I am running a steady-state (moving reference frame) Conjugated Heat Transfer (CHT) simulation with many solid parts and fluid regions.
I am using conformal mesh using shared topology.
I have noticed that after bringing my mesh into Fluent, I get a warning:
This will adversely affect the solution.
It is suggested to use the following command to solve it:
/mesh/modify-zones/slit-interior-between-diff-solids
My question:
When I have interior between solids, does it mean I do not have heat transfer between those solids?
I appreciate your inputs.
Best,
M
Milad06 is offline   Reply With Quote
Old   October 5, 2022, 19:35
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you will have heat transfer, however, temperate may be predicted inaccurate on the cells adjusted to interior
Milad06 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 7, 2022, 11:43
Milad MU
Thanks for the response.
when I tried to slit the faces, the simulation diverges (temperature divergence).
I am dealing with relatively small parts in certain regions of my model, so I know, my mesh is not good enough in those regions so maybe after the slit, it causes issue. After using the command, I of course check the mesh and get no error, but still get temp divergence.
Any suggestion regarding this issue?
I am thinking to refine my mesh in those regions, or maybe introduce all the parts as "Solid" in named selection so that it creates wall & shadow-wall properly from the beginning.
Multiphase euler foam problem with velocity vector enthusiast OpenFOAM Running, Solving & CFD 1 January 20, 2023 04:54
Averaging over iterations for steady-state simulation CFD student Fluent UDF and Scheme Programming 8 September 22, 2022 04:39
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 11:05
activeBaffleVelocity boundary condition ? om3ro OpenFOAM Programming & Development 10 November 17, 2020 00:26
Warning 097- AB Siemens 6 November 15, 2004 05:41
