August 11, 2022, 03:03 |
How to capture First shock cell?
Rep Power: 4 |
Hello.
I'm simulating compressible Sonic jets. I'm using RKE turbulent model for this. RKE model has been showing promising results. When validating with my experiments using centreline pressure decay plots, I noticed the first shock is not captured i.e. the plot shows a straight line (no total pressure gradient) upto certain distance downstream of exit. Rest of the plot holds good with the experimental findings. I tried adapting the mesh also, but couldn't capture the sharp gradients as was observed in experiments. Is there any way to solve this? Thank you. |
August 11, 2022, 03:21 |
Alexander
Rep Power: 34 |
decrease the size of mesh in region you are interested in
I don't know any other way
best regards ****************************** press LIKE if this message was helpful |
Controlling species wall flux using a UDF that checks adjacent cell species conc. | ZachFrankman | Fluent UDF and Scheme Programming | 1 | August 10, 2022 03:36 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[snappyHexMesh] Error when setting locationsInMesh | elonesampaio | OpenFOAM Meshing & Mesh Conversion | 1 | April 3, 2021 17:44 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Shock capture in CFX | BalanceChen | CFX | 2 | June 7, 2011 07:25 |
