Convergence problem
Like Tree2Likes
  • 1 Post By Indra
  • 1 Post By Indra
Old   July 20, 2022, 08:32
Default Convergence problem
黃聖淵
Yuan0218 is on a distinguished road
I want to simulation fume hood leakage problem and using k \epsilon model.
boundary condition
inlet pressure inlet= 0 p
sup1,2 velocity inlet= 1.37 m/s
outlet mass flow outlet= 0.516 kg/s
but it can't convergence.
and show this message Reversed flow on 247 faces (2.6% area) of pressure-inlet
plese help me
Yuan0218 is offline   Reply With Quote
Old   July 20, 2022, 10:56
Void_CFD-user
Indra is on a distinguished road
boundary condition
plese help me
You can select prevent reverse flow option in the pressure inlet.
Yuan0218 likes this.
Indra is offline   Reply With Quote
Old   July 20, 2022, 12:40
黃聖淵
But I want to observed inlet leakage
Old   July 20, 2022, 12:43
Void_CFD-user
Right, we'll reversed flow shouldn't be the cause for no convergence. Can you show me your solution methods? Try changing to coupled and using pseudo time step method. Also not sure how good your mesh is, but try switching to k-w sst. If you want to use k-e model, use Realisable k-e with enhanced wall treatement.
Old   July 20, 2022, 23:38
黃聖淵
this is mesh qality
what is pseudo time step
I trying to add pseudo time step but the continuity still in 1e+00
I used your suggest is this correct?
my english is not good sorry
thank you for answering my question
Old   July 21, 2022, 05:14
Void_CFD-user
this is mesh qality
your continuity is below one in the image you sent me. It seems to be going down, run it for longer. You haven't run it for long enough, you might also wanna add a monitoring point in your simulation.
If it still doesn't converge try reducing pseudo time step from 1.
Old   August 24, 2022, 06:17
黃聖淵
Sorry, I have a question, what is a pseudo time step
convergence in fluent, fume hood
Convergence problem in Fluent for quenching process kaeran FLUENT 4 December 1, 2014 03:14
Rotate frame reference convergence problem! wjy-c CFX 2 September 26, 2014 07:03
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 10:12
Convergence Problem in Axisymmetric Periodic Flow atheresia FLUENT 3 February 10, 2014 04:00
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
