Moving Energy Source
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   June 16, 2022, 17:45
Default Moving Energy Source
axt5488 is on a distinguished road
Hello Everyone,
I am working on to create a volumetric heat source (VHS) with a gaussian profile inside a simple cubic domain. I am working on Fluent 'Solidification & Melting' model. In order to create a moving volumetric heat source-VHS I am using DEFINE_SOURCE for my UDF. The equation that I am using for gaussian profile for VHS is attached [https://doi-org.ezproxy.uta.edu/10.1...0-019-04908-3]
However I have energy source equation as a function of time and position the energy source that I created did not move. Here you can see my UDF basically below
#include "udf.h"
#include "math.h"
#include "metric.h"
#include "sg.h"
#include "sg_mphase.h"
#include "mem.h"
#include "sg_mem.h"
#include "flow.h"
#include "unsteady.h"
#define A 0.24 /*Absorption coefficient*/
#define P 400 /*Laser Power*/
#define re 0.0001 /*radius on top*/
#define ri 0.0002 /*radius on bottom*/
#define zi 0.00005 /*cone length parameter lower z axis*/
#define ze 0.0001 /*cone length parameter upper z axis*/
#define v1 1.200 /*laser velocity*/
#define v2 0 /*laser velocity*/
#define pi 3.1415
DEFINE_SOURCE(heat_source, c, t, dS, eqn)
real x[ND_ND];
C_CENTROID(x, c, t);
real x0 = 0.00061, y0 = 0, z0 = 0; /*initial position of the heat flux*/
real t0 = 1; /*the time that the heat flux is stationary*/
real time = CURRENT_TIME;
real H = ze - zi;
real r0;
r0 = ri; /*r0 = re + ((ri - re) / H) * (z - ze) z-ze equals to H then r0 equals to ri*/
real d;
real Q0;
double Q = 0.0;
if (time<= 1)
Q = 0.0;
else
d = M_PI * H * pow(re, 2) + (re * ri) + pow(ri, 2);
Q0 = 6 * A * P / d;
Q = Q0 * exp(-1 * pow(x[0] - x0 - v1 * time, 2.0) + pow(x[1] - y0, 2.0) / pow(r0, 2));
dS[eqn] = 0.0;
return Q;
The script compiled without any error but the heat source did not move. Do I need to add more comments for advective flux for scalar transport equation.
This is one of the topics previously discussed for welding/AM applications in the forum but it seems it is not solved yet. I hope this time we will figure it out.
Any comments are welcome and I will be more than happy if anybody in the forum knows how to UDF a moving heat source.
Thanks in advance
Updated by Ahmet Alptug
Metadata
Views 1
Last Activity less than a minute ago
Tags ·Add
axt5488 is offline   Reply With Quote
Old   June 16, 2022, 23:38
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
coordinate of heat source location must be updated with time to make it move
as of know I can see that only magnitude of source is time dependent
axt5488 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
laser spot welding, melt pool, moving heat source
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 04:04
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
