Reference Values
Like Tree1Likes
  • 1 Post By mz_uon
Old   May 29, 2022, 08:13
Default Reference Values
Sakun
Sakun is on a distinguished road
I am simulating a compressor blade under 240 m/s, under reference values what should i insert for Area and length ?
does area means area of the blade ? and length means chord of the blade ?
i don't understand what they meant by depth as well.
appreciate for the help
Sakun is offline   Reply With Quote
Old   June 4, 2022, 16:57
mz_uon is on a distinguished road
If the reference is taken at the inlet (as in your case), then the area means that of the inlet surface.
Sakun likes this.
mz_uon is offline   Reply With Quote
Old   June 6, 2022, 17:43
Sakun
Hi
Thank you very much for your kind reply,
regarding your answer can you bit expalin, what values should it be in the depth and length ? specially when it is in 2D?
many thanks for your time.
fluent, fluent solver
[OpenFOAM.org] Compile OpenFOAM with OpenMPI+FCA v4.0.2 guilleTessi OpenFOAM Installation 6 October 18, 2019 15:13
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
It would be wonderful if a tool for FoamToTecplot is available luckyluke OpenFOAM Post-Processing 165 November 27, 2012 07:54
OpenFOAM-2.1.x on fedora 16 x86_64 anand_30 OpenFOAM Installation 3 December 26, 2011 03:09
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
