How to get Periodic Component of the Pressure? |
Shubham Sathe
Rep Power: 4 ![]() |
I am simulating a wavy fin channel with periodic inlet-outlet BC conditions. I am trying to mimic the plot below for the un-slotted wavy fin (shown by the black line): Which shows the periodic component of the pressure (Px) normalized by Kinetic energy: 1.gif From the theory, the periodic pressure can be calculated using: Px(periodic pressure) = P+(DeltaP)*x To do this, I created a custom field function: (P +( periodic-pressure-gradient*x)), I have used the periodic-pressure-gradient that is auto-generated in the report when giving the periodic condition. I plotted these Px results to get: 2.gif As this is the periodic pressure; the end and the start point should be the same as seen in the first chart. I have compared and validated the other results, so I know the model is correct. I am only facing issues with this chart. Is there any other way to get the periodic component of the pressure? |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
The pressure if you do nothing in Fluent is the periodic pressure.
Shubham Sathe
Thank you so much for the response.
fluent, periodic boundary fluent, periodic pressure, periodicity |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 20:05 |
periodic straight tube flow, no mesh independent solution for pressure gradient | thijs1909 | FLUENT | 5 | May 16, 2018 09:04 |
pressure drop of the periodic boundary! | debuger | FLUENT | 9 | April 2, 2016 14:20 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 11:26 |
