Streamlines passing through the solid bodies
Like Tree1Likes
  • 1 Post By Vestdam
Old   April 28, 2022, 06:18
Default Streamlines passing through the solid bodies
Hammad Naseem
hammadn95 is on a distinguished road
I am relatively new to Ansys Fluent. I am simulating a mask embedded with a fan. Unfortunately, after the simulation, in the results section, when I am choosing the streamlines, the lines are passing through the solid part of the mask instead of passing through the opening.
In the SETUP, the boundary conditions option has SOLID selected for these parts. For the enclosure, I only kept the fan of the mask. Since I used the enclosure in SpaceClaim, it automatically creates boolean I guess? So the boolean is only of the fan.
I am attaching the pictures of streamlines I am getting and the geometry of the mask. Please help me whoever knows the issue.
Thanks in advance
hammadn95 is offline   Reply With Quote
Old   April 28, 2022, 07:29
Void_CFD-user
Indra is on a distinguished road
Thanks in advance
Please provide more information. Show us you simulation model in spaceclaim or fluent rather than CFD Post. We need to see the full model(enclosure and walls) and boundary conditions.
Indra is offline   Reply With Quote
Old   April 28, 2022, 13:25
Default Below are the details you asked for
Hammad Naseem
Thanks for the reply.
Here as you can see, I only kept the fan in enclosure and rest of the geometry was assembled normally. When I am taking more then 1 part in enclosure, it is giving an error.
In cell zone conditions, I am setting the fan as a solid and giving it a rotational speed of 5600 rpm whereas the enclosure is set as a fluid with ZERO velocity.
In the boundary conditions, I have given inlet velocity and outlet is set as pressure. The contact regions are set as interface and interiors are set as walls.
Old   April 29, 2022, 02:55
Vestdam
Vestdam is on a distinguished road
Hi Hammad,
If the first figure shows the enclosure, you are bringing to the mesher/solver, you have not enclosed or subtracted the mask solid. You need to create the enclosure around both objects (fan and mask).
hammadn95 likes this.
Vestdam is offline   Reply With Quote
Old   May 2, 2022, 04:33
Hammad Naseem
Thanks for the reply. I did try to bring other parts of mask into the enclosure but the problem is that I am not able to create enclosure on more then 1 part of the assembly. It's giving me an error.
Old   May 2, 2022, 04:35
Vestdam
You probably need to simplify the geometry and possibly merge the parts before making the enclosure. Then you can split it up afterwards.
Old   May 3, 2022, 08:04
Hammad Naseem
I'm sorry but can you explain a bit more. Because if I merge the mask and fan in one body and then make enclosure of the whole geometry, later on in the solvent I won't be able set the condition (rpm) of the fan for simulation.
Old   May 5, 2022, 01:39
Vestdam
I guess the problem originates from the geometry stage.. You are not able to create an enclosure around both bodies, which means that you need to either simplify the geometry and find the cause of the software not being able to enclose them, or you need to combine the bodies, make the enclosure and then split up the domains afterwards. If you slice/split up the enclosure, you should be able to isolate the fan domain.
cfd - post, fluent solver, streamlines
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) Adam_K OpenFOAM Running, Solving & CFD 2 March 27, 2019 07:51
[ANSYS Meshing] ANSYS 2D Geometry/Meshing Plugin Error: Attach Failed, No Valid Bodies Found cdase ANSYS Meshing & Geometry 0 August 26, 2018 15:31
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
Interpreting streamlines of a rotating fan. danbence Visualization & Post-Processing 1 April 8, 2014 11:13
Defining Solid Zones Not working elmcmaster FLUENT 3 May 22, 2009 08:14
