Ross Grant
Rep Power: 4 ![]() |
I am trying to replicate the paper "effects of geometry and inconsistent mass flow rate on temperatures within a pressurized hydrogen cylinder during refueling", (Li et al). The boundary conditions specify a mass flow rate of 0.025 kg/s, initial tank pressure of 2 MPa, initial gas temperate of 293 K and a final gas pressure of 35 MPa. However, a gas inlet pressure ramp rate is specified at 45 MPa. What does this ramp rate mean and how do I specify it considering I already have a mass flow rate inlet. Regards, Ross |
Ben Johns
Rep Power: 0 ![]() |
Did you solve this problem at all, I am having a similar issue with specifying pressure ramp rates.
Ross Grant
No I never got it sorted in time. Apologies! |
fluent, gas compression, gas heating, hydrogen |
postprocessing result pressure in the inlet using simplefoam | rjomega | OpenFOAM Verification & Validation | 0 | March 20, 2022 02:39 |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 10:34 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Specifying a Flow's Mass Flow Rate and Inlet Pressure | Jayhawk | STAR-CCM+ | 16 | March 20, 2015 16:03 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
