What is the Y+ base heat transfer coefficient in ANSYS fluent solution ?
Like Tree1Likes
  • 1 Post By LuckyTran
Old   January 29, 2022, 02:24
Default What is the Y+ base heat transfer coefficient in ANSYS fluent solution ?
kmech
Kmech is on a distinguished road
I have problem to recognize output value of my CFD solution but there are many heat transfer coefficient in solution.
In this solution there are Surface heat transfer coefficient, wall heat transfer coefficient and Specified Y+ based HEAT TRANSFER COEFFICENT.
In this results What is Y+ based HEAT TRANSFER COEFFICENT? Please give proper reason for particularly Ansys Fluent CFD.
Kmech is offline   Reply With Quote
Old   January 29, 2022, 04:44
Lucky
It's not specific to Fluent and not special to Fluent. You deal with this everywhere in heat transfer. "Heat transfer coefficient" is not a unique parameter. For any amount of heat flux, you define a heat transfer coefficient for a given reference temperature. There are as many distinct heat transfer coefficients are there are reference temperatures (i.e. an uncountable number).
The specified Y+ based heat transfer coefficient takes a user input of y+. The reference temperature value is obtained locally via the temperature at the specified wall Y+ value. The heat transfer coefficient is then calculated using this temperature at Y+ of (some number). The idea is that using this reference temperature at some Y+ value, you get a heat transfer coefficient that is more universal than some arbitrary free stream reference temperature value because all boundary layers look just about the same once I am inside the boundary layer. If none of these benefits appeals to you, then just simply don't use the specified Y+ based heat transfer coefficient and continue to use your own reference temperature.
8cold8hot likes this.
Old   March 20, 2023, 08:44
atelcikti1's Avatar
atelcikti1 is on a distinguished road
actually it has been implemented in Star CCM+ for a long time. Its better to see in Fluent also. If you dont have defined reference temperature ie. simple problems like flow in pipe, its better to use yplus based htc.
I have now a good question i think. Do we have access to other flow variables (rho, velocity etc.) at specific yplus. Fluent simply implemented to find reference temperature, i guess background is ready. Did they put into UDF variables, anyone has info?
atelcikti1 is offline   Reply With Quote
Old   March 20, 2023, 12:20
Lucky
It's much older than Star. Rescaling based on inner coordinates has been around for over a century and was what motivated Prandtl to come up with boundary layer theory in the first place. Not that I wasn't aware of its implementation in Star since I've been using it for over a decade. Btw, it was implemented in Fluent before it was implemented in Star.
y* based heat transfer coefficient is just a means to rescale wall heat fluxes or wall BC's. Unless it is a wall flux, it makes no sense to request flow variables at a given *. If you want actual cell properties at a given y*, that would just be the cell properties. Conversely, you have the Tref, just calculate the properties at the given Tref.
ansys 21 r1 cfd, cfd, y+ htc
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 17:29
Interphase mass transfer of a reaction cfx_ws1992 Main CFD Forum 0 May 15, 2017 22:42
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 09:48
