Iteration in applying boundary conditions till some goal is met in solution
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   January 24, 2022, 12:50
Post Iteration in applying boundary conditions till some goal is met in solution
Rohit Kanchi
rohitroxkp7 is on a distinguished road
Hello all, I was wondering if some automation in the application of boundary conditions was possible. My problem involves repeatedly reducing exit pressure till the exit mach reaches a certain value. If I could simply iterate the same till it happens, it would help a lot. Maybe write a code in the boundary conditions or solver where it iterates for each pressure value till convergence and if exit mach is not matching required mach, reduce pressure by a certain amount and then continue.
Alternately, I could go for a transient analysis with pressure varying with time in the boundary conditions. I can give timesteps and do the same. I would like to know in which way should I go about it.
rohitroxkp7 is offline   Reply With Quote
Old   January 25, 2022, 01:01
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
transient simulation probably will take more time, ofc everything depends on your settings.
you may control almost everything using TUI commands
write them into scheme, however, code requires some knowledge from you.
rohitroxkp7 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 25, 2022, 01:06
Rohit Kanchi
thanks a lot
fluent - parallel
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 12:14
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 06:58
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
