How should the aerogel material be defined in the fluent?
Like Tree2Likes
  • 1 Post By Kummi
  • 1 Post By AlexanderZ
Old   November 18, 2021, 10:03
Exclamation How should the aerogel material be defined in the fluent?
Alluna
Alluna is on a distinguished road
Hello there ,
I will use the aerogel material for a cooling analysis that I will perform in Fluent. Although aerogel is a solid material, it has a very porous structure, but I cannot choose a solid material as porous in fluent right ? Is there anyone who can help with this?
Cooling analysis tries to measure conduction heat transfer and determine how long the aerogel will protect the box from high temperature.
Alluna is offline   Reply With Quote
Old   November 18, 2021, 13:57
Kumaresh
Kummi is on a distinguished road
Send a message via Yahoo to Kummi
Hello Alluna,
Yae you can't define the solid material as porous in fluent. Aerogel is the lightest solid, however you need to consider under fluid regions in Fluent.
What really matters for porous zone, as how you define the inertial and viscous terms.
Good luck
Alluna likes this.
Kummi is offline   Reply With Quote
Old   November 19, 2021, 00:52
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
in other words you may try to model it as a fluid with huge viscosity.
in addition you may apply porous zone
Alluna likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 19, 2021, 04:02
Alluna
Many thanks to both of you, these ideas were really helpful.
aerogel, conductive zones, heat transfer in fluent
CFX error (Overflow) with particular user defined material UsamaQ CFX 8 April 10, 2020 13:18
Will fluent update temperature automatically when enthalpy in every cell is defined? Weiqiang Liu FLUENT 0 September 16, 2019 13:22
Add Young's Modulus and Poisson Ratio to a material into Fluent florian.crepin Fluent UDF and Scheme Programming 4 April 30, 2019 14:04
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
