October 26, 2021, 06:43 |
FLUENT TUI Command for input-parameters
#1 | |
Lukas
Rep Power: 5 |
currently I'm trying to change an input parameter via a journalfile. I tryed the solution from #2 in Input Parameters in Fluent Standalone but that doesn't seem to work anymore. I tryed Quote:
Have they changed the command or how could I get it to work? Thanks in advance! Lukas |
October 26, 2021, 10:07 |
Alexander
Rep Power: 34 |
most likely you don't have any parameters yet.
to create a parameter do following Code:
define parameters input-parameters advance use-in udf-side "parameter_name" value
best regards ****************************** press LIKE if this message was helpful |
October 26, 2021, 10:23 |
#3 | |
Lukas
Rep Power: 5 |
Thank you very much! |
how to run fluent from matlab without using aas toolbox? | artemis96 | ANSYS | 7 | May 23, 2022 13:16 |
Fluent TUI command - mechanical option in CFD solver | mperrin | FLUENT | 1 | October 15, 2021 11:16 |
TUI commands last Fluent version | JJ Wey | Fluent UDF and Scheme Programming | 2 | January 15, 2016 08:48 |
How to define parameters for multi periodic boundary conditions in Fluent | uuusheng | FLUENT | 1 | October 14, 2014 07:48 |
Error with FLUENT TUI transient-export function | DarrenC | FLUENT | 0 | March 14, 2011 18:30 |
