Total pressure drop in laminar channel flow (calculation of friction factor)
Like Tree1Likes
  • 1 Post By LuckyTran
Old   October 24, 2021, 13:16
Default Total pressure drop in laminar channel flow (calculation of friction factor)
oliver_houxiao's Avatar
HOU Xiao
oliver_houxiao is on a distinguished road
Hello everyone,
I'm calculating the total pressure drop at Re = 2000, for water at 300K in a pip D = 0.1 m, L = 2 m. And this is a verification for the other studies.
The problem is, the theoretical result for friction factor is around f = 64/Re = 0.032, but the result is much higher (f = 0.0729).
Could you help me to verify my settings as follows?
Re = 2000, density: 998.2 kg/m^3, viscosity: 0.001003 kg/(m s)
As a result:
hydraulic-diameter: 0.1 m (for pip D = 0.1 m)
inlet-velocity: 0.0201 m/s
sandgrain roughness height = 0
Results:
Area-Weighted Average Total Pressure: inlet: 0.49894214 Pa
outlet: 0.20497435 Pa
friction-factor: f = 0.0729 >> 0.032
Did I make a mistake of common sence or there are something special to be noticed?
oliver_houxiao is offline   Reply With Quote
Old   October 24, 2021, 18:48
Lucky
64/Re is for fully developed flow.
Are you using streamwise periodic BC's or is this with a velocity inlet and outlet type calculation? You might need to take into account developing effects.
oliver_houxiao likes this.
Old   October 2, 2023, 02:27
Question the result is not matching with theoretical calculation
Sumeet kotak
sumeetkotak is on a distinguished road
I am facing the same issue.
Simple fluid Flow problem
Problem Description:
Pipe diameter: 0.0478 m
density: 998 kg/m^3
Velocity: 0.036 m/s
theoretical calculation:
Re: 1500
Friction factor f=64/Re
delta P= 0.57 Pa
Fluent Analysis:
Inlet BC: Velocity inlet
outlet BC: Pressure outlet 0 Pa (atmospheric condition)
Model: laminar
Result:
Pressure at inlet: 1.23 Pa
delta P = pressure inlet - pressure outlet = 1.23-0 = 1.23 Pa which is 115% higher than theoretical value.
Need help
Thanks in advance
sumeetkotak is offline   Reply With Quote
Old   October 2, 2023, 02:57
Lucky
A velocity inlet is not a fully developed flow. The theoretical value for this case is NOT 64/Re. You can find in engineering handbooks the apparent friction factor for developing cases. Use the right formula! It should not match 64/Re. If anyone matches 64/Re for a developing flow then either they are a liar or they have messed up.
If you want to match 64/Re then use periodic BC's so that you do have a fully developed flow, or apply the fully developed profile at the inlet, or make the pipe super long so that entrance effects can be ignored.
Old   October 5, 2023, 07:26
Sumeet kotak
Thanks for your response.
Can you help me how to apply fully developed profile as velocity inlet ?
Thanks in advance
fluent, friction factor, pip flow, pressure drop
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
SimpleFoam Laminar Pipe Flow Pressure Drop Error xiaolong OpenFOAM Running, Solving & CFD 3 September 16, 2019 11:37
Total pressure drop & static pressure drop Aarthar Main CFD Forum 3 April 11, 2018 04:32
Pressure drop across a turbulent channel flow shiv Main CFD Forum 0 September 21, 2005 01:52
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
