October 17, 2021, 08:00 |
ANSYS Fluent 2021R2 on Rocky 8.4+
Rep Power: 16 |
If you wish to install Fluent on some current Linux distribution such as the "new CentOS 8" Rocky or Alma Linux then you might run into troubles since ANSYS does not officially support 8.4 and above. Not to worry though, it is quite easy to make it work anyway.
Here are some notes from the installation. Hopefully it can help someone. Do the following before you run the installation (if you already have installed it then I suggest removing the files and also deleting the .ansys folder in your home directory) NOTE: I have installed this on a fresh Rocky 8.4 installation with the "Workstation" software package plus "Development tools" and "Scientific computing". 1. Check and install all dependencies uner §1.5 in the installation guide. There are a few missing dependencies though so after you have checked the list, also: 2. Install libnsl and tcsh Code:
sudo dnf install libnsl tcsh Code:
Error: Error in CAD Import Error Object: #f Error: Importing selected file could not be completed. Check to make sure the selected file format is supported. In addition, check to make sure the CAD Readers are properly configured for the format using the CAD Configuration Manager Utility. Error Object: #f I have not found any strange behavior after this, connected to either Design Modeler, Meshing, Fluent Meshing or Fluent. Unsupported Linux distros / unsupported Linux distro versions / modern Linux distros / installation of ANSYS on linux / ANSYS 2021R2 / Fluent 2021R2 |
May 11, 2022, 23:01 |
#2 | |
Arvind Jay
Rep Power: 15 |
For Debian:
May 12, 2022, 02:46 |
Rep Power: 16 |
You have not written which version of Debian. If you are on anything newer than 9 then I doubt that is sufficient to get it working. Could you please confirm if all functionality is there, i.e. test design modeler as well as meshing (generate mesh!)?
With ANSYS 2022r2 they may have support for Ubuntu 20.04, which in turn means that most semi-new distros will work. |
GPU acceleration in Ansys Fluent | flotus1 | Hardware | 63 | May 12, 2023 03:48 |
Fluent in Ansys Workbench : Change Working Directory | sral | FLUENT | 4 | March 29, 2019 11:29 |
Using ANSYS Fluent 18.0 on workstations with multiple network cards and PBS Pro | cheezum | Hardware | 0 | February 28, 2017 11:23 |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 13:07 |
error in opening fluent in ansys workbench | tmeysam92 | ANSYS | 3 | March 12, 2013 07:10 |
