Error estimator - adaptive mesh - Ansys Fluent |
Nathália Melo
Rep Power: 0 ![]() |
Dear all,
I am a beginner in numerical simulation. I would like to ask if it is possible to get the values calculated by the adaptive mesh error estimator in Ansys Fluent. Thank you for your kind cooperation. |
Marcin
Rep Power: 13 ![]() |
can u describe Ur problem more precisely??
In Fluent U have Dynamic Mesh option for example. U can set this in automatic mode
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
Nathália Melo
Dear Martin_Sz,
I am performing a simulation of a two-phase, two-component flow. To reduce the computational cost, I have performed simulations applying dynamic adaptive mesh, with the error estimator based on the mass fraction gradient of one of the species of the two-component phase. At the end of the simulations, I would like to obtain an adapted mesh that has an error close to the error of the mesh in which I did not use dynamic adaptivity. However, I do not know how I can perform this comparison in Fluent or if there is another way that I can compare the solutions obtained with adaptivity and without adaptivity. Thank you for your kind cooperation. |
adaptive mesh, ansys fluent, error estimator |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Exporting Mesh from Pointwise to ANSYS FLUENT | mrswordf1sh | Pointwise & Gridgen | 14 | September 6, 2017 10:23 |
Ansys Fluent Mesh to be Used in Mechanical Thermal System | jjlt | ANSYS | 0 | January 26, 2017 01:50 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
