Definition of strain rate for axisymmetric case in ANSYS Fluent
Like Tree1Likes
  • 1 Post By LoGaL
Old   August 26, 2021, 18:07
Default Definition of strain rate for axisymmetric case in ANSYS Fluent
Jnandeep
puddingLeaf is on a distinguished road
The strain rate magnitude(STRAIN_RATE-MAG(c,t)) is defined in header files as:
sqrt(ND_SUM(ND_DOT(C_DUDX(c,t), C_DUDY(c,t), C_DUDZ(c,t),(C_DUDX(c,t) + C_DUDX(c,t)),(C_DUDY(c,t) + C_DVDX(c,t)),(C_DUDZ(c,t) + C_DWDX(c,t))),ND_DOT(C_DVDX(c,t), C_DVDY(c,t), C_DVDZ(c,t),(C_DVDX(c,t) + C_DUDY(c,t)),(C_DVDY(c,t) + C_DVDY(c,t)),(C_DVDZ(c,t) + C_DWDY(c,t))),ND_DOT(C_DWDX(c,t), C_DWDY(c,t), C_DWDZ(c,t), (C_DWDX(c,t) + C_DUDZ(c,t)),(C_DWDY(c,t) + C_DVDZ(c,t)),(C_DWDZ(c,t) + C_DWDZ(c,t))))
+ (rp_axi ? (2.*SQR(C_V(c,t)/C_AVE_Y(c,t)) + (sg_swirl ? (SQR(C_AVE_Y(c,t))*NV_MAG2( C_STORAGE_R_NV(c,t,SV_OMEGA_G))): 0.)): 0.))
I understand the first part of the definition which is basically the second invariant of the strain rate tensor. But for axisymmetric case part(rp_axi part) I don't get how those terms appear. Can anyone explain/refer to any theory <span class="highlighter highlight-on">resource</span> to learn how those terms appear for axisymmetric case? Also, I can't find definition of the terms too in the manual.
puddingLeaf is offline   Reply With Quote
Old   August 27, 2021, 01:11
Lorenzo Galieti
LoGaL is on a distinguished road
Hi, this blue component contains the term due to the swirl. It is zero if there’s no flow rotation around the axis, but i think in fluent you can run “axi-symmetric” simulations also including swirl velocity
puddingLeaf likes this.
LoGaL is offline   Reply With Quote
Old   August 27, 2021, 04:00
Jnandeep
Hello. Thanks for your reply. Actually, I am writing a UDF for viscosity that is based on the third invariant of the strain rate tensor. So, for a 2D axisymmetric case, I am stuck on what those swirl terms will be for the third invariant. Can you help me with this?
axisymmetric, strain rate, strain rate tensor, strainrate(), udf code
Epyc 7551 vs 6850K; Ansys Mechanical Bench Duke711 Hardware 24 March 26, 2020 11:16
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
special case in ansys fluent eytworld ANSYS 0 March 31, 2013 04:06
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
