PR Yi
Rep Power: 4 ![]() |
I want a case to be calculated to 500 iterations by force.
But as you know, when the calculation done, it stops by itself (like in 100 or 221 of iterations, before 500 iterations.) Is there any way to force Fluent calculate? I mean if I set 500 number of iterations, Fluent calculate 500. and if I set 1500 number of iterations, Fluent calculate 1500, whether its calculation is done or not. English is not my mother language so, sorry for my bad English ![]() |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Fluent will do however many iterations you want unless you set stopping criteria. These are usually the convergence monitors. Simply turn them off. Uncheck the boxes that say check convergence.
PR Yi
Ah, I think I found it at Residual Monitors > Advanced option.
Thank you so much!! |
ansys, calculate, continue calculation, fluent |
Lift and Drag Force - 3D Wing ANSYS FLUENT | jonsyesause | FLUENT | 0 | April 26, 2017 12:31 |
ansys fluent v16.0 :problem whit resume calculation and automatic export file | ca3tiel | FLUENT | 0 | May 29, 2016 19:08 |
UDF in Fluent | Andrew | Fluent UDF and Scheme Programming | 5 | March 7, 2016 03:38 |
exporting drag force from fluent | fluentguy | FLUENT | 2 | October 27, 2009 14:19 |
On Bug of Fluent 12.0 | lzgwhy | FLUENT | 0 | August 26, 2009 06:41 |
