coyote
Rep Power: 5 ![]() |
Hi everyone,
I'm doing a thermal parametric study in fluent. I found how to parametrize boundary conditions. Nevertheless, I could not find how to parametrize initial conditions. I want to parametrize the values found under : Solution initialization In particular : Temperature (k). Thanks for helping, Coyote |
Alexander
Rep Power: 34 ![]() ![]() |
you may use journal files to control your case
using TUI commands inside you may define everything you want
best regards ****************************** press LIKE if this message was helpful |
coyote
Based on the answer given by @AlexanderZ
I created this explanation back in stackoverflow |
fluent, parameter, parametrization |
How to get good initialization in parameter simulation? | cfd2020 | FLUENT | 2 | May 9, 2020 21:17 |
How to realize this way of initialization in parameter simulation? | cfd2020 | FLUENT | 0 | May 1, 2020 11:38 |
[PyFoam] running pyFoam(Plot)Runner.py in parallel | Studi | OpenFOAM Community Contributions | 10 | September 6, 2015 16:38 |
meshing of a compound volume in GMSH | shawn3531 | OpenFOAM | 4 | March 12, 2015 10:45 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
