May 12, 2021, 05:59 |
Add units to expression using TUI
Rep Power: 7 |
Hey all you awesome Fluent users out there......
I have what is probably a very simple question I would like to define a constant using the TUI to be used in calculations during a run. Very simply I would like to have: Length = 6m (as in 6 metres). I thought I could do something like this: /solve/report-definitions/add length expression define..... but then I run into not knowing how to code for the units at the Enter Expression: [""] prompt. Help greatfully accepted!!! |
September 12, 2022, 15:39 |
Rep Power: 7 |
For new named expression
/define/named-expressions/add length definition "1.1[m]" () To edit existing named expression /define/named-expressions/edit length definition "1.2[m]" () |
September 15, 2022, 19:48 |
Rep Power: 7 |
Thanks D.W.!
expression, fluent, tui, units |
[swak4Foam] outputTime in Swak function | immortality | OpenFOAM Community Contributions | 20 | October 6, 2022 13:08 |
[swak4Foam] how to add an inlet expression using groovyc | m5m5kh | OpenFOAM Community Contributions | 8 | May 17, 2021 11:44 |
Error occurs when I set the Opening Temperature using an expression | doublestrong | CFX | 6 | April 1, 2016 08:30 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 07:16 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
