Coupled analysis with Peltier module
Like Tree2Likes
  • 1 Post By woodwax
  • 1 Post By woodwax
Old   March 7, 2021, 12:32
Default Coupled analysis with Peltier module
Valaki Valami
woodwax is on a distinguished road
I would like to modell coupled system with Peltier module.
The Peltier is modelled with Mechanic, other parts with Fluent.
Hot side of the module is on heatsink, it has a fixed wall temperature of 280K.
Cold side of the module is on PCB with air, enclosed with metal walls.
See the attached picture.
After some coupling iteration I get the known error temperature limited to 1.000000e+00 in 57967 cells on zone 17 in domain 1. So I started debug the problem and I found out that after ~10 coupling iterations the Total heat transfer rate (found on Fluent->Monitors->Report Plots->Flux Report->Total heat transfer rate->Chose the Peltier surface) is gets very big some 10 W, see attached picture.
I don't know why that problem appears. Can anyone have any idea?
Thank you.
cobal likes this.
woodwax is offline   Reply With Quote
Old   March 9, 2021, 03:20
Valaki Valami
I further investigated the problem and found a solution of reducing the Under Relaxation Factor to 0.05 or even smaller value.
My theory is that the Fluent cannot handle the arising heat shortage (from the Thermal-Electric solver) on the cold side of the Peltier because the thin (0.8mm) FR4-epoxy and air there, have a very very small amount of heat capacity and conductivity (850J/Kg*K; 0.29W/mK for FR4).
Is that a correct approach of solving that problem? 0.05 for Under Relaxation Factor seems to me very small value. Is there possible another solution?
if I put a thin (0.1mm) thermal paste layer (with high thermal conductivity) between Peltier and FR4-epoxy can help?
Old   March 9, 2021, 13:39
Valaki Valami
On the first approach, I reduced the Under Relaxation Factor until the solution doesn't converge. I earn convergency at value 0.045 with 1000 iterations which is so so much.
One of my ideas is to put a thermal paste layer between the Peltier modules (which I solve in Thermal-Electric solver) and the PCB (which I solved in Fluent). With that approach, the solution started to converge at Under Relaxation Factor 0.2 with about 300 iterations which is much less than in the previous solution.
See the attached pictures.
cobal likes this.
Generating Stack Trace while solving johny_walker OpenFOAM Running, Solving & CFD 1 January 29, 2021 03:48
InterFOAM water channel case Error mkjmalik OpenFOAM Running, Solving & CFD 4 August 23, 2020 11:32
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload ingjuanm90 ANSYS 0 July 26, 2016 14:04
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
Coupled 1D/3D STAR-CD Training CD adapco Group Marketing Siemens 1 November 13, 2002 15:48
