Supersonic Overexpanded Impinging jet - Convergence issue
Like Tree1Likes
  • 1 Post By Guillaume Crn
Old   February 17, 2021, 15:08
Default Supersonic Overexpanded Impinging jet - Convergence issue
Guillaume Crenn
Guillaume Crn is on a distinguished road
I am working on impinging jets and to get confidence with Fluent, I am trying to get similar results from a template report. This report has been written by Xu and al. (2011), « Particle image velocimetry study of the impinging height effect on an overexpanded supersonic impinging free jet at Ma=1.754. Part I: global coherent structure and Part II : detailed velocity distribution ».
Here are the speficiations :
  • Ma = 1.754
  • Nozzle Pressure Ratio (NPR) = 4.7625
  • T = 300K
And I used this geometry :
I have obtained a mesh qualified as "good" by mesh metrics spectrum from ANSYS, with inflation (First layer thickness at 2.27e-6m).
I obtained quite good results with Pressure based (Axisymmetric option, SST K-omega, Energy : On, Pressure Inlet : 482 560.3 Pa from the NPR, Pressure Outlet : 101 325 Pa, Scheme : Coupled, 2nd order, steady state) but there is a physical inconsistency at the centreline :
Given the Mach number (and so the high velocities), I have chosen to use the Density-Based Solver with the axisymmetric option, SST K-omega, Energy : On, Pressure Inlet : 482 560.3 Pa given from the NPR, Pressure Outlet : 101 325 Pa, operating condition : P = 0 Pa (absolute value), T=300K, Formulation : Implicit, Flux Type : Roe 2nd order.
BUT this time I can't have a convergent solution. I tried Pseudo Transient, no Pseudo Transient, starting with 1st Order and change in 2nd after having a stable (but no converging) solution, decrease the factors, increase and decrease the courant number (Without Pseudo Transient), using a Time Scale Factor of 0.1 , 0.01 , 0.001 and 0.0001...
And I tried these for many iterations..
I can't have residuals below 1e-2 (target : 1e-6)
Yet, the velocity contours, (for this no convergent solution) show a better solution without the physical inconsistency :
Do you have a idea why I can't have a convergent solution ? How Can I have a more robust solution ?
Thank you !
Saintree likes this.
Guillaume Crn is offline   Reply With Quote
Old   February 5, 2022, 22:40
Nathan CHEN
Saintree is on a distinguished road
Hi Guillaume
I may have a solution for this kind of situation.
First I have to say I cannot see any of the figures in this page, and what I am doing is a rotor blade instead of a jet. So my case (research object, working condition, etc) is quite diffrent from yours.
However, the thing is that I have met exactly the same thing as you did, convergent with pressure-based solver but divergent with density-based solver. What I tried to solve this was to set the operating pressure=101325 Pa, and the gauge pressure=0 Pa. I know it is not recommended by Fluent but it was the only way I solved this problem and got a reasonable result of the flow field.
So far I don't know why and this does not seem to happen everytime. Technically when velocity is high it is more suitable to set the operating pressure as 0, but for my case it just could not converge.
Hope my solution could help you. If you know the reason for this, or you have found another solution to your issue, please tell me as well and we could discuss this in more detail.
Thanks
Nathan
Saintree is offline   Reply With Quote
impinging, jet, overexpanded, residuals, supersonic
Setup of impinging jet model ritwik_101 Main CFD Forum 1 October 30, 2017 04:49
Grid Convergence Study in Cold Plasma Jet Mourousias Main CFD Forum 2 July 9, 2016 15:14
Supersonic Jet Flows Danny Tan FLUENT 0 November 30, 2001 22:01
impinging jet data Andreas Abdon Main CFD Forum 4 January 19, 2000 08:40
IMPINGING JET ........... HELP!!!!!!!! Amir Omoumi Main CFD Forum 10 August 30, 1999 23:11
