Laminar model not converging
Like Tree3Likes
  • 2 Post By ashkan.ghafari92
  • 1 Post By LoGaL
Old   February 10, 2021, 23:26
Default Laminar model not converging
Juan Cisneros
ufo20 is on a distinguished road
Hello Fluent users,
I am analyzing the hydrodynamic flow in a wastewater treatment reactor with Re = 450. The laminar model was chosen for the simulation. A polyhedra-based mesh with approximately 1.3M cells was generated in fluent meshing. The mesh has an average and maximum skewness of 0.12 and 0.5, respectively.
I use the coupled pressure-based solver and second-order upwind discretization schemes. To initialize the simulation, I use hybrid initialization. However, with this setup, I have not been able to get a converged solution, the velocity residuals do not drop below 1e-3, and the continuity residual rises above 0.
I am attaching images of the reactor, the baffles, the water inlet, outlet and the residuals.
I am looking forward for someone's advice.
Cheers Juan
ufo20 is offline   Reply With Quote
Old   February 11, 2021, 17:27
ashkan.ghafari92's Avatar
ashkan ghafari
ashkan.ghafari92 is on a distinguished road
There are some tips you can try :
1- use first-order upwind discretization at the beginning of the simulation.
2- reduce the courant number or urf in the solution control section.
3- use transient solver.
ufo20 and marcusaurelius like this.
ashkan.ghafari92 is offline   Reply With Quote
Old   February 12, 2021, 08:32
Lorenzo Galieti
LoGaL is on a distinguished road
Hi juan,
The mesh is good, so no problem about that. I would only put some more elements in the pipe inlet and extend it a fair bit (6-8 Diameter lengths). You need to have developed flow entering the reactor, place the inlet far away from where interesting stuff happens. This may also help with convergence
Apart from that, let me understand better: is there something spinning inside the reactor? Like a sort of propeller? If yes, no wonder the steady simulation doesn't converge
ufo20 likes this.
LoGaL is offline   Reply With Quote
convergence failure, fluent - parallel, laminar model
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Eulerian-Eulerian turbulent two-fluid model is not converging? minzhang Fluent Multiphase 26 April 24, 2020 05:13
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 19:19
choosing turbulence model for gas phase while laminar model for solid phase Haiqin STAR-CCM+ 3 July 12, 2016 05:45
Is Non premixed combusiton (flamelet model) in Fluent able to calculate laminar? sooroo3 FLUENT 2 November 10, 2013 06:47
