February 8, 2021, 01:16 |
Rotate and Power/Torque
devansh
Rep Power: 5 |
I have designed a turbine with similar characteristics to a wind turbine. I am trying to achieve the following:
1. rotate the turbine from the air that is hitting it 2. Calculate power/torque |
February 8, 2021, 03:07 |
Rep Power: 7 |
I think that what you describe can be done using the 6DOF solver, but it would be a very difficult and expensive simulation (I've never done that so I can't help further). A more pragmatic approach is to prescribe the angular velocity and measure th quantities of interest (e.g.torque). Of course, the rotation speed is unknown at this point so you have to calculate many operating points and effectively construct the characteristics of the turbine. You can then interpolate between the calculated points (outside of cfd).
February 8, 2021, 03:20 |
#3 | |
devansh
Rep Power: 5 |
And I am using Fluent, is this sought of analysis done in fluent or CFX? which one is better? thank you |
February 8, 2021, 03:27 |
Rep Power: 7 |
If you decide to use the approach I suggested, then both Fluent and CFX are fine. You will need to create a cylindrical domain around the turbine and apply a rotating reference frame. There are tutorials on this, try looking for "MRF".
February 8, 2021, 15:45 |
Yasser Selima
Rep Power: 19 |
Not only SDOF. You can use CG_Motion as well.
Calculate the moment around the axis of rotation, then apply Newton's second law to solve for the new rotational velocity and provide it to the solver. |
power, rotate, torque |
