Unbound Variable Error when using command line |
January 26, 2021, 13:42 |
Bella Barbera
Rep Power: 6 |
Hello everyone, I am writing a journal file so I can run ANSYS Fluent remotely. I have been testing the file on my side first before I send it in however I have been trying to fix this error which happens when I am reading my journal file. It happens when I am reading in my UDF as an interpreted function.
I have tried correcting the input to be cpp instead of "cpp" but neither is accepted. Does anyone know why or what the input at this command line should be? I must fix it via the command line NOT the GUI. Thank you!! |
January 27, 2021, 02:18 |
Alexander
Rep Power: 34 |
change to
\"cpp\"
best regards ****************************** press LIKE if this message was helpful |
January 28, 2021, 11:53 |
Bella Barbera
Rep Power: 6 |
I did end up using a black space instead. Basically the equivalent to hitting enter if you were at the command promt, which worked. Thank you!
Error: eval: unbound variable | mardar572 | FLUENT | 1 | June 13, 2023 10:12 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 10:14 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 05:35 |
Error: access: unbound variable | cfd-novice | FLUENT | 0 | April 3, 2003 05:53 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
