Rep Power: 5 ![]() |
Hi everyone, I am new to this forum and quite unexperienced with Fluent as well. I know that this question has already been answered but I couldn't really solve my issues.
From a RTD analysis I know that in a tubular reactor there are dead zones. I would like to take a contour of residence time inside the reactor in order to know where the dead zones are, so I would need to create a uds for mean residence time.. I already found a code here but when I run the simulation the uds is always equal to zero. Anyone can help? Thank you very much in advance ![]() |
Alexander
Rep Power: 34 ![]() ![]() |
you don't need UDF to get mean values
there is an option "data sampling for time statistics", you may use it solution -> run calculation -> options but if you are telling us, that your UDF doesn't work, you should put it here with detailed description of your model and problems, with console output and so on
best regards ****************************** press LIKE if this message was helpful |
Alexander, thank you very much for your answer, but in the sampling options I can't see the residence time, I think that I have to compile a UDF function.
I post here what I previously found /*========================*/ #include "udf.h" /* * UDF to compute fluid residence time * * This UDF requires at least 1 UDS to be defined * At inlet, define UDS (value) = 0 * UDS will have units of time and represent approximate residence time * of fluid in domain * * Diffusivity of scalar should be small to reduce diffusion i.e. 1E-5 * However, for turbulent flow with recirculating regions, it is more appropriate * to hook the function rtd_diff to the UDS diffusivity in the * materials panel */ DEFINE_SOURCE(rt_source,c,t,dS,eqn) { real source = C_R(c,t); dS[eqn] = 0.0; return source; } /* * in the function below, the turbulent schmidt number has been * set to 1.0 in accordance with the references mentioned above * and the fluid molecular diffusivity has been set to 1.0e-5 m2/s * * these values can be changed on an as-needed basis, for instance in * Airpak mean age of air calculations, a value of 2.88e-5 is used * for the molecular diffusivity and a value of 0.7 is used for the * turbulent Schmidt number */ DEFINE_DIFFUSIVITY(rtd_diff, c, t, i) { return C_R(c,t)*1.0e-09+C_MU_EFF(c,t)/1.0; } What I do is: 1) Compile the udf function 2) setting a UDS 3)setting the boundaries condition (0 at the inlet) Then I run a transient simulation but the residence time is always equal to zero and never increases. I hope to have explained my problem properly, thank you ![]() |
Alexander
did you apply UDS source in Fluent GUI to the fluid zone?
go to zone -> select fluid -> sources -> uds-0 -> select your UDF source
anonymous96
Rep Power: 3 ![]() |
Hello Alexander
I have a problem after exporting UDF output to a text file. I am running simulation on a cluster and it runs well. I basically have 2 issues: a)The value of UDS appears to be zero in the console for all the iterations. UDS is for the concentration of species which are emitted from a cell zone. Please note that the source is specifies in GUI and not the UDF. A snippet of my code is as follows: DEFINE_ON_DEMAND(pch_udf) { FILE* fp_pch; fp_pch = fopen("PCH.txt", "a"); Thread *t,*to, ; face_t f; cell_t co; Domain *d; d = Get_Domain(1); real A[ND_ND]; real x[ND_ND]; real PCH_turb_roof=0; //loop for turbulent component of PCH(Roof) thread_loop_f(t, d) { begin_f_loop(f,t) { F_CENTROID(x, f, t); if (x[0] >= 108 && x[0] <= 126 && x[1] == 18 && x[2] >= 90 && x[2] <= 126 ) { F_AREA(A,f,t); co = F_C0(f, t); to = THREAD_T0(t); real integrand; real conc_grad_roof; real mu_t_roof = C_MU_T(co,to); C_UDSI(co,to,0)= C_YI(co,to,0) * RHO_1; conc_grad_roof=(C_UDSI_G(co,to,0)[1]); integrand = (mu_t_roof /0.7)*conc_grad_roof; PCH_turb_roof -= integrand*NV_MAG(A); } } end_f_loop(f,t) } fprintf(fp_pch, "PCH_turb_roof %g\n",PCH_turb_roof); } b) After complete simulations, the parameters defined under execute on demand are 0 for some iterations and non zero for some in the output text file. but it should be non-zero after every iteration as far as I understand. Please let me know if I am doing something wrong or interpreting them wrong. A snippet of the output file is as follows: PCH_turb_roof 0 PCH_turb_side1 0 PCH_turb_side2 0 PCH_mean_roof 0 PCH_mean_side1 0 PCH_mean_side2 0 PCH_turb_roof 0 PCH_turb_side1 0 PCH_turb_side2 0 PCH_mean_roof 0 PCH_mean_side1 0 PCH_mean_side2 0 PCH_turb_roof 0 PCH_turb_side1 0 PCH_turb_side2 0 PCH_mean_roof 0 PCH_mean_side1 0 PCH_mean_side2 0 PCH_turb_roof 0 PCH_turb_side1 0 PCH_turb_side2 0 PCH_mean_roof 0 PCH_mean_side1 -4.6371 PCH_mean_side2 4.36109 PCH_turb_roof 0 PCH_turb_side1 0 PCH_turb_side2 0 PCH_mean_roof 0 PCH_mean_side1 0 PCH_mean_side2 0 PCH_turb_roof 0 PCH_turb_side1 0 PCH_turb_side2 0 PCH_mean_roof 0 PCH_mean_side1 0 PCH_mean_side2 0 PCH_turb_roof 0 PCH_turb_side1 0 PCH_turb_side2 0 PCH_mean_roof 0 PCH_mean_side1 0 PCH_mean_side2 -4.1951 |
Alexander
first of all
compile your code and fix errors
anonymous96
Hello Alexander
Thankyou for the response. Code is compiled successfully and runs without any error. The only problem is it gives zero values for the parameters. However I fixed it partially using PRF_GRSUM1 which was suggested by you in some other thread I came across and it works and gives desired output for other parameters. But the only problem is the piece of code mentioned above. I have come to realize that the problem is with C_UDSI_G term because I am getting 0 for only those parameters which include C_UDSI_G. I am attaching the code again for your reference: Code:
#include "udf.h" #include "sg.h" #include "mem.h" #include "math.h" #define RHO_1 1.29 DEFINE_ON_DEMAND(pch_udf) { FILE* fp_pch; fp_pch = fopen("PCH.txt", "a"); Thread *t,*to; face_t f; cell_t co; Domain *d; d = Get_Domain(1); real A[ND_ND]; real x[ND_ND]; real PCH_turb_roof=0; thread_loop_f(t, d) { begin_f_loop(f,t) { F_CENTROID(x, f, t); if (x[0] >= 108 && x[0] <= 126 && x[1] == 18 && x[2] >= 90 && x[2] <= 126 ) { F_AREA(A,f,t); co = F_C0(f, t); to = THREAD_T0(t); real integrand; real conc_grad_roof; real mu_t_roof = C_MU_T(co,to); C_UDSI(co,to,0)= C_YI(co,to,0) * RHO_1; conc_grad_roof=(C_UDSI_G(co,to,0)[1]); integrand = (mu_t_roof /0.7)*conc_grad_roof; PCH_turb_roof -= integrand*NV_MAG(A); } } end_f_loop(f,t) } } |
Alexander
..\..\src\debug_request_1.c(11) : error C2275: 'Thread' : illegal use of this type as an expression ...\src\storage\mem.h(279) : see declaration of 'Thread' ..\..\src\debug_request_1.c(11) : error C2065: 't' : undeclared identifier ..\..\src\debug_request_1.c(11) : error C2065: 'to' : undeclared identifier ..\..\src\debug_request_1.c(11) : error C2100: illegal indirection ..\..\src\debug_request_1.c(12) : error C2275: 'face_t' : illegal use of this type as an expression ...\src\storage\mem_grid.h(119) : see declaration of 'face_t' ..\..\src\debug_request_1.c(12) : error C2146: syntax error : missing ';' before identifier 'f' ..\..\src\debug_request_1.c(12) : error C2065: 'f' : undeclared identifier ..\..\src\debug_request_1.c(13) : error C2275: 'cell_t' : illegal use of this type as an expression ...\src\storage\mem_grid.h(124) : see declaration of 'cell_t' ..\..\src\debug_request_1.c(13) : error C2146: syntax error : missing ';' before identifier 'co' ..\..\src\debug_request_1.c(13) : error C2065: 'co' : undeclared identifier ..\..\src\debug_request_1.c(14) : error C2275: 'Domain' : illegal use of this type as an expression ...\src\storage\mem.h(277) : see declaration of 'Domain' ..\..\src\debug_request_1.c(14) : error C2065: 'd' : undeclared identifier ..\..\src\debug_request_1.c(15) : error C2065: 'd' : undeclared identifier ..\..\src\debug_request_1.c(15) : warning C4047: '=' : 'int' differs in levels of indirection from 'Domain *' ..\..\src\debug_request_1.c(17) : error C2275: 'real' : illegal use of this type as an expression ...\src\main\global.h(174) : see declaration of 'real' ..\..\src\debug_request_1.c(17) : error C2146: syntax error : missing ';' before identifier 'A' ..\..\src\debug_request_1.c(17) : error C2065: 'A' : undeclared identifier ..\..\src\debug_request_1.c(17) : error C2109: subscript requires array or pointer type ..\..\src\debug_request_1.c(18) : error C2275: 'real' : illegal use of this type as an expression ...\src\main\global.h(174) : see declaration of 'real' ..\..\src\debug_request_1.c(18) : error C2146: syntax error : missing ';' before identifier 'x' ..\..\src\debug_request_1.c(18) : error C2065: 'x' : undeclared identifier ..\..\src\debug_request_1.c(18) : error C2109: subscript requires array or pointer type ..\..\src\debug_request_1.c(20) : error C2275: 'real' : illegal use of this type as an expression ...\src\main\global.h(174) : see declaration of 'real' ..\..\src\debug_request_1.c(20) : error C2146: syntax error : missing ';' before identifier 'PCH_turb_roof' ..\..\src\debug_request_1.c(20) : error C2065: 'PCH_turb_roof' : undeclared identifier ..\..\src\debug_request_1.c(21) : error C2065: 't' : undeclared identifier ..\..\src\debug_request_1.c(21) : error C2065: 'd' : undeclared identifier ..\..\src\debug_request_1.c(21) : error C2223: left of '->f' must point to struct/union ..\..\src\debug_request_1.c(21) : error C2065: 't' : undeclared identifier ..\..\src\debug_request_1.c(21) : warning C4047: '!=' : 'void *' differs in levels of indirection from 'int' ..\..\src\debug_request_1.c(21) : error C2065: 't' : undeclared identifier ..\..\src\debug_request_1.c(21) : error C2065: 't' : undeclared identifier ..\..\src\debug_request_1.c(21) : error C2223: left of '->next' must point to struct/union ..\..\src\debug_request_1.c(23) : error C2065: 't' : undeclared identifier ..\..\src\debug_request_1.c(23) : error C2223: left of '->nelements' must point to struct/union ..\..\src\debug_request_1.c(23) : error C2065: 'f' : undeclared identifier ..\..\src\debug_request_1.c(23) : error C2065: 'f' : undeclared identifier ..\..\src\debug_request_1.c(23) : error C2065: 'f' : undeclared identifier ..\..\src\debug_request_1.c(25) : error C2065: 'x' : undeclared identifier ..\..\src\debug_request_1.c(25) : error C2109: subscript requires array or pointer type ..\..\src\debug_request_1.c(25) : error C2065: 't' : undeclared identifier ..\..\src\debug_request_1.c(25) : error C2223: left of '->storage' must point to struct/union ..\..\src\debug_request_1.c(25) : error C2065: 'f' : undeclared identifier ..\..\src\debug_request_1.c(25) : error C2065: 'x' : undeclared identifier ..\..\src\debug_request_1.c(25) : error C2109: subscript requires array or pointer type ..\..\src\debug_request_1.c(25) : error C2065: 't' : undeclared identifier ..\..\src\debug_request_1.c(25) : error C2223: left of '->storage' must point to struct/union ..\..\src\debug_request_1.c(25) : error C2065: 'f' : undeclared identifier ..\..\src\debug_request_1.c(25) : error C2065: 'x' : undeclared identifier ..\..\src\debug_request_1.c(25) : error C2109: subscript requires array or pointer type ..\..\src\debug_request_1.c(25) : error C2065: 't' : undeclared identifier ..\..\src\debug_request_1.c(25) : error C2223: left of '->storage' must point to struct/union ..\..\src\debug_request_1.c(25) : error C2065: 'f' : undeclared identifier ..\..\src\debug_request_1.c(26) : error C2065: 'x' : undeclared identifier ..\..\src\debug_request_1.c(26) : error C2109: subscript requires array or pointer type ..\..\src\debug_request_1.c(26) : error C2065: 'x' : undeclared identifier ..\..\src\debug_request_1.c(26) : error C2109: subscript requires array or pointer type ..\..\src\debug_request_1.c(26) : error C2065: 'x' : undeclared identifier ..\..\src\debug_request_1.c(26) : error C2109: subscript requires array or pointer type ..\..\src\debug_request_1.c(26) : error C2065: 'x' : undeclared identifier ..\..\src\debug_request_1.c(26) : error C2109: subscript requires array or pointer type ..\..\src\debug_request_1.c(26) : error C2065: 'x' : undeclared identifier ..\..\src\debug_request_1.c(26) : error C2109: subscript requires array or pointer type ..\..\src\debug_request_1.c(28) : error C2065: 'A' : undeclared identifier ..\..\src\debug_request_1.c(28) : error C2109: subscript requires array or pointer type ..\..\src\debug_request_1.c(28) : error C2065: 't' : undeclared identifier ..\..\src\debug_request_1.c(28) : error C2223: left of '->storage' must point to struct/union ..\..\src\debug_request_1.c(28) : error C2065: 'f' : undeclared identifier ..\..\src\debug_request_1.c(28) : error C2065: 'A' : undeclared identifier ..\..\src\debug_request_1.c(28) : error C2109: subscript requires array or pointer type ..\..\src\debug_request_1.c(28) : error C2065: 't' : undeclared identifier ..\..\src\debug_request_1.c(28) : error C2223: left of '->storage' must point to struct/union ..\..\src\debug_request_1.c(28) : error C2065: 'f' : undeclared identifier ..\..\src\debug_request_1.c(28) : error C2065: 'A' : undeclared identifier ..\..\src\debug_request_1.c(28) : error C2109: subscript requires array or pointer type ..\..\src\debug_request_1.c(28) : error C2065: 't' : undeclared identifier ..\..\src\debug_request_1.c(28) : error C2223: left of '->storage' must point to struct/union ..\..\src\debug_request_1.c(28) : error C2065: 'f' : undeclared identifier ..\..\src\debug_request_1.c(29) : error C2065: 'co' : undeclared identifier ..\..\src\debug_request_1.c(29) : error C2065: 't' : undeclared identifier ..\..\src\debug_request_1.c(29) : error C2223: left of '->storage' must point to struct/union ..\..\src\debug_request_1.c(29) : error C2065: 'f' : undeclared identifier ..\..\src\debug_request_1.c(30) : error C2065: 'to' : undeclared identifier ..\..\src\debug_request_1.c(30) : error C2065: 't' : undeclared identifier ..\..\src\debug_request_1.c(30) : error C2223: left of '->t0' must point to struct/union ..\..\src\debug_request_1.c(31) : error C2275: 'real' : illegal use of this type as an expression ...\src\main\global.h(174) : see declaration of 'real' ..\..\src\debug_request_1.c(31) : error C2146: syntax error : missing ';' before identifier 'integrand' ..\..\src\debug_request_1.c(31) : error C2065: 'integrand' : undeclared identifier ..\..\src\debug_request_1.c(32) : error C2275: 'real' : illegal use of this type as an expression ...\src\main\global.h(174) : see declaration of 'real' ..\..\src\debug_request_1.c(32) : error C2146: syntax error : missing ';' before identifier 'conc_grad_roof' ..\..\src\debug_request_1.c(32) : error C2065: 'conc_grad_roof' : undeclared identifier ..\..\src\debug_request_1.c(33) : error C2275: 'real' : illegal use of this type as an expression ...\src\main\global.h(174) : see declaration of 'real' ..\..\src\debug_request_1.c(33) : error C2146: syntax error : missing ';' before identifier 'mu_t_roof' ..\..\src\debug_request_1.c(33) : error C2065: 'mu_t_roof' : undeclared identifier ..\..\src\debug_request_1.c(33) : error C2065: 'to' : undeclared identifier ..\..\src\debug_request_1.c(33) : error C2223: left of '->storage' must point to struct/union ..\..\src\debug_request_1.c(33) : error C2065: 'co' : undeclared identifier ..\..\src\debug_request_1.c(33) : fatal error C1903: unable to recover from previous error(s); stopping compilation
#9 |
anonymous96
It is surprising because I am working on a cluster and the code compiles successfully without any error and even runs properly. I have tried the same on GUI and it runs properly even there. Below is the output given by cluster.
> /define/user-defined/execute-on-demand "ach_udf::libudf"top_area 488.745640 ACHt_mean_out 774.856324 ACHt_mean_in -1566.653054 ACHs1_mean_out 594.815464 ACHs1_mean_in -1454.835132 side1_area 372.217786 ACHs2_mean_out 557.829449 ACHs2_mean_in -512.963930 side2_area 235.807022 ACHt_turb_out 1174.266788 ACHt_turb_in -1174.266788 ACHs1_turb_out -1315.378930 ACHs1_turb_in 1315.378930 ACHs2_turb_out 531.245672 ACHs2_turb_in -531.245672 > /define/user-defined/execute-on-demand "pch_udf::libudf"PCH_turb_roof 0.000000 PCH_turb_side1 0.000000 PCH_turb_side2 0.000000 PCH_mean_roof -231.858120 PCH_mean_side1 -251.835431 PCH_mean_side2 13.137737 |
#10 |
anonymous96
Here is the messages on compilation in HPC:
done # linking to ../../src/codasc_udf.c in lnamd64/3ddp_host # linking to ../../src/udf.h in lnamd64/3ddp_host # building library in lnamd64/3ddp_host make[1]: Entering directory `/scratch/21ef91r04/Trial2/libudf/lnamd64/3ddp_host' # Generating udf_names.c because of codasc_udf.c make[2]: Entering directory `/scratch/21ef91r04/Trial2/libudf/lnamd64/3ddp_host' make libudf.so "CFLAGS=-D_lnamd64 -D_GNU_SOURCE -fpic -shared -std=c99 -Wall -O -DPTR_RESTRICT= " "LDFLAGS=-shared -lm" make[3]: Entering directory `/scratch/21ef91r04/Trial2/libudf/lnamd64/3ddp_host' # Compiling udf_names.o because of udf_names.c cc -D_lnamd64 -D_GNU_SOURCE -fpic -shared -std=c99 -Wall -O -DPTR_RESTRICT= -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/`expr "\`pwd\`" : '.*/\(.*\)/[23].*'`/`basename "\`pwd\`"` -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/main -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/addon-wrapper -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/io -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/species -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/pbns -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/numerics -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/sphysics -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/storage -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/mphase -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/bc -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/models -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/material -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/amg -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/util -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/mesh -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/udf -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/ht -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/dx -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/turbulence -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/acoustics -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/parallel -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/etc -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/ue -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/dpm -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/dbns -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/cortex/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/client/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/tgrid/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/multiport/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/multiport/mpi_wrapper/include -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/multiport/mpi_wrapper/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/include -I. -c udf_names.c # Compiling codasc_udf.o because of codasc_udf.c cc -D_lnamd64 -D_GNU_SOURCE -fpic -shared -std=c99 -Wall -O -DPTR_RESTRICT= -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/`expr "\`pwd\`" : '.*/\(.*\)/[23].*'`/`basename "\`pwd\`"` -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/main -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/addon-wrapper -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/io -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/species -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/pbns -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/numerics -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/sphysics -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/storage -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/mphase -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/bc -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/models -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/material -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/amg -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/util -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/mesh -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/udf -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/ht -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/dx -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/turbulence -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/acoustics -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/parallel -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/etc -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/ue -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/dpm -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/dbns -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/cortex/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/client/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/tgrid/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/multiport/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/multiport/mpi_wrapper/include -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/multiport/mpi_wrapper/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/include -I. -c codasc_udf.c # Linking libudf.so because of udf_names.c udf_names.o codasc_udf.o cc -shared -lm udf_names.o codasc_udf.o -o libudf.so make[3]: Leaving directory `/scratch/21ef91r04/Trial2/libudf/lnamd64/3ddp_host' make[2]: Leaving directory `/scratch/21ef91r04/Trial2/libudf/lnamd64/3ddp_host' make[1]: Leaving directory `/scratch/21ef91r04/Trial2/libudf/lnamd64/3ddp_host' # linking to ../../src/codasc_udf.c in lnamd64/3ddp_node # linking to ../../src/udf.h in lnamd64/3ddp_node # building library in lnamd64/3ddp_node make[1]: Entering directory `/scratch/21ef91r04/Trial2/libudf/lnamd64/3ddp_node' # Generating udf_names.c because of codasc_udf.c make[2]: Entering directory `/scratch/21ef91r04/Trial2/libudf/lnamd64/3ddp_node' make libudf.so "CFLAGS=-D_lnamd64 -D_GNU_SOURCE -fpic -shared -std=c99 -Wall -O -DPTR_RESTRICT= " "LDFLAGS=-shared -lm" make[3]: Entering directory `/scratch/21ef91r04/Trial2/libudf/lnamd64/3ddp_node' # Compiling udf_names.o because of udf_names.c cc -D_lnamd64 -D_GNU_SOURCE -fpic -shared -std=c99 -Wall -O -DPTR_RESTRICT= -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/`expr "\`pwd\`" : '.*/\(.*\)/[23].*'`/`basename "\`pwd\`"` -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/main -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/addon-wrapper -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/io -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/species -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/pbns -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/numerics -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/sphysics -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/storage -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/mphase -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/bc -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/models -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/material -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/amg -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/util -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/mesh -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/udf -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/ht -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/dx -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/turbulence -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/acoustics -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/parallel -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/etc -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/ue -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/dpm -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/dbns -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/cortex/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/client/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/tgrid/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/multiport/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/multiport/mpi_wrapper/include -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/multiport/mpi_wrapper/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/include -I. -c udf_names.c # Compiling codasc_udf.o because of codasc_udf.c cc -D_lnamd64 -D_GNU_SOURCE -fpic -shared -std=c99 -Wall -O -DPTR_RESTRICT= -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/`expr "\`pwd\`" : '.*/\(.*\)/[23].*'`/`basename "\`pwd\`"` -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/main -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/addon-wrapper -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/io -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/species -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/pbns -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/numerics -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/sphysics -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/storage -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/mphase -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/bc -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/models -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/material -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/amg -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/util -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/mesh -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/udf -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/ht -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/dx -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/turbulence -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/acoustics -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/parallel -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/etc -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/ue -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/dpm -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/src/dbns -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/cortex/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/client/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/tgrid/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/multiport/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/multiport/mpi_wrapper/include -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/fluent21.2.0/multiport/mpi_wrapper/src -I/home/apps/ANSYS2021R2/installdir/ansys_inc/v212/fluent/include -I. -c codasc_udf.c # Linking libudf.so because of udf_names.c udf_names.o codasc_udf.o cc -shared -lm udf_names.o codasc_udf.o -o libudf.so make[3]: Leaving directory `/scratch/21ef91r04/Trial2/libudf/lnamd64/3ddp_node' make[2]: Leaving directory `/scratch/21ef91r04/Trial2/libudf/lnamd64/3ddp_node' make[1]: Leaving directory `/scratch/21ef91r04/Trial2/libudf/lnamd64/3ddp_node' |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 02:05 |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
