Energy conservation (total heat transfer rate)
Like Tree1Likes
  • 1 Post By lei
Old   November 18, 2020, 22:08
Lightbulb Energy conservation (total heat transfer rate)
cfdEng_ is on a distinguished road
I would have a naive question about energy conservation on Fluent.
Background: My domain is very simple: BL flow over a flat plate.
Problem: If I calculate the total heat transfer rate at the inlet (Report>Fluxes>Total heat transfer rate) and I compare it with the value I get from CFD-post: areaInt(Density*Velocity u*CP*T0)@inlet, the two results are completely different.
By checking the energy balance from Report>Fluxes>Total heat transfer rate, energy conservation is respected. However, it is not with CFD-post.
Am I doing something wrong?
Thank you in advance.
cfdEng_ is offline   Reply With Quote
Old   November 19, 2020, 03:53
Moritz Kuhn
MKuhn is on a distinguished road
Check if you have the same reference state for calculating the enthalpy. Maybe in Fluent Total heat transfer rate at a flow boundary is only massflow by enthalpy, without the kinetic part. But I'm not sure.
MKuhn is offline   Reply With Quote
Old   November 19, 2020, 06:47
Default nusselt number
physics baali
somia baali is on a distinguished road
Hello every one
my geometry is 3D flat plate solar collector
i want to ask you about calculating Nusselt number in fluent
i try in fluent -report-surface integral-area weight average-wall flux- surface nusselt number but the result is incorrect
please help me how can i found correct result
somia baali is offline   Reply With Quote
Old   November 19, 2020, 08:25
I think you are right. Apparently Fluent uses Tref=298.15K as the reference temperature in all enthalpy calculations.
Therefore, if I work out areaInt(Density*Velocity u*CP*(T0-298.15[K]))@in I get the same result that comes from the total heat transfer rate calculation. By adopting Tref, the energy balance holds on CFD-post as well.
What puzzles me is whether Tref=298.15K is also used to calculate the wall heat flux. Any idea?
Old   November 19, 2020, 08:42
Moritz Kuhn
I would say, the value of the wall heat flux at a flow boundary is quite meaningless if you consider the single value. It is only usable for the caluclation of the energy conservation (sum up of all wall boundaries), because in this case you don't care about the reference state.
Old   November 19, 2020, 15:14
For stationary flows, I get a pretty good approximation in terms of energy balance.
On the other hand, I am still experiencing a severe energy imbalance in the turbulent regime (implicit LES). Is there a quick way to assess the energy balance for transient flows with Fluent?
Old   November 19, 2020, 16:01
Lorenzo Galieti
LoGaL is on a distinguished road
Which one are you controlling for imbalance? Average one or istantaneous one?
LoGaL is offline   Reply With Quote
Old   November 24, 2020, 11:59
lei
Lei Chen
lei is on a distinguished road
The Nu number and HTC calculation in Fluent depends on the ref temperature settings, please make sure you set a meaningful reference value in the Reference Values panel before calculating heat transfer coefficients.
https://www.afs.enea.it/project/nept...ug/node972.htm
Originally Posted by somia baali View Post
Hello every one
somia baali likes this.
lei is offline   Reply With Quote
Old   November 29, 2020, 05:51
physics baali
thank you for your reply, your answer is true, my problem now in how can i determine the reference values
Old   November 29, 2020, 05:55
physics baali
thank you so much Lei, your reply is true, but my problem now in how can i determine the reference values exactly.
energy balance, heat transfer convergence
Flow around heatsink with heat transfer S Mughal FLUENT 0 April 13, 2018 14:06
Error in run Batch file saba1366 CFX 4 February 10, 2013 02:15
natural convection mehrdadeng CFX 10 February 25, 2011 06:25
Total Heat Transfer Rate & Total Surface Heat Flux Mismatch icaro FLUENT 0 November 24, 2009 08:01
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
