Mesh Interface problem. Please help!!
Like Tree1Likes
  • 1 Post By saikath65
Old   September 21, 2020, 15:17
Angry Mesh Interface problem. Please help!!
Mahmud Hasan Saikat
saikath65 is on a distinguished road
I have a wind turbine model. The stationary and rotating domain is connected by sliding mesh interface. The problem is when fluent loads the case, the turbine blades are also loaded as interface. So in boundary condition the blades are loaded twice as wall and interface. There is nothing contacting with the blades. They should just be walls. In the photo you can see the Rotating Domain.
Thank you. Please help me!!
saikath65 is offline   Reply With Quote
Old   September 22, 2020, 12:23
srsel6 is on a distinguished road
Hi, there's too little information here to help you. Could you describe your problem in detail as well as what you've done to try and fix it. Post some pictures as well.
srsel6 is offline   Reply With Quote
Old   September 23, 2020, 14:18
Talking Solved!!
Mahmud Hasan Saikat
Hello! I actually solved the problem. The rotating domain diameter was 1 meter. After setting it to 1.1m the problem was solved. So I'm guessing fluent has some preset value for interface or something like that. I don't know.
srsel6 likes this.
mesh interface rotating, mesh interfaces, sliding mesh model, wind turbine
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
[Other] splitMeshRegions does not create interface patch between regions fsan OpenFOAM Meshing & Mesh Conversion 10 June 6, 2022 06:56
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
